No spark
I'm trying to get a 93 SVX running again. No spark. I'm told it should be the crank sensor, cam sensor, ignition module or a combination. Anyone have a better way to narrow it down than just throwing parts at it?
Does anyone out there these parts they need to get rid of? If I can't get it going, the next step is to sell it as is. That is an option if anyone is interested. Ran great before this. |
Is the Check Engine Light coming on? You can get the diagnostic codes on a 93 yourself. Go up top to the "How To Documents" -> "engine" for instructions on running the diagnostics.
No spark, no check engine light, nothing as a clue. It was running a little rough, like a plug was bad, changed the plugs with little improvement. A few days later, it just wouldn't start. After changing a few parts out, the dealer told the mechanic working on it that it could and may be a combination of the parts.
Check the timing belts? Pull off one of the side covers.
