Ignition Module Input/Output
Does anyone know the specifics of the SVX Ign. Module.
Input voltages, output and dwell, volts, mA to fire coils ect. I'm going with stand alone engine management. Thanks |
Anybody?
Has anybody scoped the input? |
I guess I should answer my own question in case someone else is going stand alone and wants to retain the factory module.
I purchashed an oscilliscope and took some readings. The module recieves a 4.0V - 4.2V signal from the computer. The dwell @ Idle is 2.4ms 1000RPM is 2.4ms 2000RPM is 2.2ms 3000RPM is 2.0ms 4000RPM is 2.0ms 5000RPM is 2.0ms Now I have to find out the crank and cam sensors. Like at what degree is the crank at when the tooth is lined up with the sensor. Would anyone have that information? Also the IAC valve is it votage or PWM? |
My guess is that at any given time EITHER pin A or pin C has a 12V PWM signal on it. (PWM means it switches rpaidly between 0 and 12 V, and the ratio of high to low determines the shutter position). Is there anybody out there who knows or can check ? |
