The element must be arranged to be insulated from extraneous heat and be in free air. This factor will have a profound affect regarding a practical possible location, as well the make up of the sensor. The physical aspects of the MAF provide food for thought. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Look at the AEM temp sesor that I found on ebay. It is a wire probe that extends into whatever the chamber is that you are tapping. From looking at it I believe that it would be free from reading parasitic heat from the manifold. What do you think, Trevor?
Do a ![]() You are delving into an area of considerable interest and figures would be worthwhile. I would not be surprised if it will prove difficult to better the OEM set up, in respect of NA engine. Let us know how you get on, Trevor. ![]()
The item has not ended. Look at the second URL listed. The auction does not end for 2 days. AU and NZ aren't THAT far ahead of us
Now that I see what you were talking about earlier Bobby, the 2nd sensor looks like the way to go.
tap manifold, use some hollow threaded rod instead of bung, and rig up a translation box to match the output of the new sensor to the output of the old sensor. Which is the part I don't know enough about. I've only done that sort of thing following instructions for a specific application. That was for getting the touchscreen in my reatta designed to read data from a series 1 3800 to display the correct data from a series 2 3800 turbo
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
I am getting this http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29 and then sort of doing what Speedklix said above. I am not sure if I will wire it into my climate control. I would like to but need to know more about the climate control first.
What is designed to be inserted/mounted into, a heat conductive or an insulating material? I can see no evidence of thermal insulation between the probe and mounting. ![]() ![]()
![]() P.S. Best option of the two. Can you do some research and find more information. Is a thermistor incorporated? If so what are its specifications? What is it designed to mate up with?
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 10-10-2007 at 10:27 PM. Reason: P.S. Added |
It must be accepted that any transducer will require time to react and this should allowed for accordingly.
![]() Trying to utilize the climate control in some way is not a good idea. ![]() Hold off for a day or two and I will try to come up with something. ![]()
Alright... Will do.
#28
N.B. Those interested should back track, as there a several posts now involved.
