Even with the newer engine... I wouldn't use the cheap gas... eewww!!!
You could always get radical cams to move the stock SVX torque to 6000rpm. That should be good for 261hp @ 6000rpm. Might need a high stall torque converter though.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
OR... Build your eg33, fully forged rods, pistons, full headwork (cams, valves, mild P&P) and you will have a much stronger motor making more HP N/A for less $$. You will also have a great platform for going F/I should you ever decide to do so.
The new six cylinder engine is in many ways very much compromised. Commercial aspects dictated that it must fit existing floor pans in production and be no longer than the four cylinder units. It was remarkable that this was achieved, but sacrifices in respect of the ideal, were made along the way.
IMHO the SVX EG33 engine is a superior unit, and most certainly has a stiffer bottom end. There will have been improvements in engine management systems along the way and this will reflect in respect of the performance of the later unit.
Fifteen years and .3 litres later and they can only give me another 20 horsepower?
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
You will have to remember that it is not just "buy the engine and drop it in". You will need the wiring harness as well and you will need to rewire the car. Wiring will be very time consuming and therefore costly. You can get all the internals from ecutune.com. CP pistons, Eagle H-beam rods, and the full valve train. If you did that with a nice exhaust, a (now that it has been proven) good intake, and a 5my swap I would venture to guess that you would see just over 200whp. Being in Utah is not working in your favor I have to be honest. The two Tom's are almost equally far away from you. The components for the motor will run about $2800-$3000 I think. Find a reputable shop near you or pay shipping and have young Tom (tomssvx) do it.
I just saw your signature too. "5mt in progress"... Perfect that in tandem with that motor and you will have a very fun car and a good base should you ever decide to join the "dark side" aka HP chasers
i wasnt trying to bash anybody I was simply stating that it is VERY expensive to change motors espically if you change rods, cams , pistons , valves etc. not to forget the miles of wiring that would have to be planted in the car to support the change now to just rebuild different story. I rebuilt a 2jz toyota which was built ALOT more of so ideally parts cheaper and I spent approx $4500 on parts only with myself doing the major work (other than planing heads block etc) it still took me a week working on it 10 hours a day if you compute the labor cost @ $85 an hour (you can get cheaper ) * roughly $5900 in labor so yes if you want to build it with unlimited $ to spend then have at it. I love reading about the mods being done to the EG33/EJ33 since I can appreicate how much love AND $ are being involved in making a 500+ whp car with or with out auto tranny
William |
EZ36's should be cheap soon as its not going to be popular. Forget going forced induction on one for real power. Even the EZ30 has proven to be ultra easy to pop under boost even when built.
So if you can get an EZ36, and you can run a standalone on it then it should be an easy swap. Better MPG, lower emissions, better daily drivablity. No racing though as its largely "done" as stock since it was designed as an emissions motor. however you might note that you just spent $3-4K for something that you will have to cheat through smog in many places. |
Yup, been watching Perrin and others nuke EZ30R's for a while now. Its a good idea that they were chasing, only the weakness of an emissions motor, not designed for boost and power keeps it from being worth it.
Very much the same deal starting with the 2.5RS engine Vs the STi engine. Even with rods and pistons you are behind the 8 ball in duriblity compared to the factory motor. Look at the time, money, and experience LAN puts into his built motors for the SVX, and its FAR better basis for performance than the EZ30 in terms of "likely to puke" The EZ36 is even weaker. Its built to do one thing, and one thing well. Power 4K lbs tribecas on piss-gas. Its going to be completely worthless for making 600HP. So if you want to engineswap for cheap power, Forester STi engines are effectively the same as our STi engines, and not too much. Or Swap a built EG33. EZ36 swaps for "fun" would be on my list, but the ECUs with the imobilizer are going to be hell to "swap". Maybe we will get lucky and some idiot with time on thier hands will figure out how to swap imobilizer ECU equipped drivetrains. |
#28
ya, actually my 5mt swap just finished today, with one exception. My rear diff is being an asshole and making noises, might be that when I switched the carrier baring into the new diff it didn't get put in completely right, so I'm having my buddies at this tranny shop look at it on monday. Other than that the car runs great! Just waitin' to finally drive the beast.... n I have the green cold air from motor sport installed with also a custom catback exhaust I had done a few years ago with I believe its 2 1/2 or 3 inch piping all the way back into a flowmaster camero style muffler and out into two 2 1/2 in. tips sounds pretty damn sexy....
#29
also on another note... I will be going back to fl for school... so, if I do decide to do the engine swap while I'm there.... that's closer than Utah. lol but still, if not I might take it to cali where my cousin who does a lot of work with cars n knows the SVX well might help me out... I don't feel like paying for labor... plus it's fun doing your own mods, as frustrating as it can get sometimes. Thanks again for the input guys I'm just doin some research now while I save money n stuff so that hopefully next summer I'll be able to do the engine work.
