fuel pump
Basically I had the fuel pump replaced, brought the car home, all has been fine for a couple days, I drove it this morning, all was fine once again and now it wont start.
I took the hose off at the fuel filter, and once again no fuel. So I opened the little door in the trunk area to see if I could hear the pump and I noticed a hose that was not connected. ![]() Is this an old connection or is this hose suppose to go somewhere? ![]()
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd |
Looks to me like you have an unconnected tube there as well...
As in, a tube that needs a connection, and an open connection.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
I wonder if some lines have been replaced and the other ones just left there. The only way you could tell is by following them or find out if there is resistance when air is put into it.
There are three connected lines.
One is the fuel line, one is the fuel return line, and one is a vent tube. All three of these lines snake above the gas tank, in front of the suspention in front of the drivers rear wheel. They then go up through the floor and through the interior and out under the hood by the fuel filter. ![]() I would replace those clamps with actual hi pressure fuel line clamps and check to see if those lines are actually FUEL INJECTION LINES. fire suck! ![]()
There's a possibility that the metal lines had rusted through, so someone bypassed them with rubber tubing. Definately listen to OT, replace those clamps and check for tubing rated for fuel injection. It will state that along the tubing somewhere.
Thanks guys for the help, My lines did rust out about 6 months ago. A local tuffy replaced them with rubber lines, but I thought they would have removed the old stuff. - This is why I don't like other people working on my car unless its someone I know and trust. They should have removed the old stuff.
Fuel related things I am a bit nervous about messing with. I don't want it to go kaboom! I will make sure to get proper hose clamps. And check the hoses to make sure they are the right kind. Fuel pump is definately not working. ![]() ![]()
There are two electronic modules in the trunk that control the fuel pump. A resistor and a modulator. If either of those are not working or not grounded the fuel pump will not run.
You may want to investigate those a little further, especially if it was a new fuel pump.
Grounds are very important here as well so check your grounds around there. Our racer had a grounding issue and died on the track when it had an exhaust break (which was giving the fuel pump it ground. |
When I had the last pump replaced, they checked the wiring to make sure it was not an electrical issue. (this car has been cursed with electrical gremlins) Assuming they knew what they where doing, the wiring should be fine.
I have a diagram of the grounding points somewhere, i'll have to check that out just incase though. When you turn the key, it makes absoluely no noise at all indicating the pump is trying to work. It could be the new one is just faulty. Which is what I am actually hoping for. - With this car, I am rarely that lucky though. ![]()
I would put my money on the relay. Out all the Subies I've owned I've never had a fuel pump go bad nor have I know anyone who had one go bad, let alone 2! Look at the wiring and I think you'll have a positive there if you test it that is hot all the time, I thiink the system works via the ground but don't quote me on that. I'll try to find a few minutes in the morning to look at my book (just as Hocrest how rare that one is!) ![]() You didn't put sand in your gas tank right? Last edited by benebob; 01-06-2008 at 04:59 PM. |
lol, no sand in the gas tank.
The SVX got worked on today, and it seems as it was a wiring issue. I guess one of the wires was connected, but not connected enough to make the pump work. It now runs, so hopefully this was the only problem. Thanks again guys!
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd Last edited by wannarace928; 01-07-2008 at 10:21 PM. |
Glad you got her back on the road. ![]() |
There is a big difference in hose and fuel hose.... and there is a more important difference in fuel hose and "fuel injection hose" which Tom attempted to point out.... but without clarification of the fact that there are two types you'll make the same error 90% of parts places do, they'll just cut you some fuel hose and sell it to you.. it'll be wrong. It MUST say that it is safe to use on fuel injected systems... many consumer parts stores usually sell it (if they sell it) boxed in pre-cut lengths... at least that is what I have found.
when clamping a hose, never tighten it to bulge... you're asking for a split! ...and the "dual" (also incorrect type) hose clamp arrangement is just scary to me.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts -
![]() [SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not ![]() Member #995 ![]() Catch you next at: ? Auto-X ? |
