Passenger Headlight very dim
So I don't think my passenger headlight is working right. And I know its not the bulb cause I have tried them both and they both work in the drivers side but not the passenger side. The reason for this I believe is that I sprayed some engine cleaner over the engine and didn't cover the wires. So how would I go about fixing this? I don't want to get a ticket, and I'm sure the stupid Corvallis police will give me one.
Thanks David
David '94 Laguna Blue L 110,000 5000k Hid's, K&N drop-in filter, leather seats(thanks to mysvxrocks), 350z rims, and now with big dent in rear passenger quarter panel Purchased 12/2007 and lovin it [SIGPIC][/SIGPIC] |
Re: Passenger Headlight very dim
Have you inspected the passenger side wiring to see if there's any visible corrosion of the wires?
hi beam or lo beam?
High beam doesn't even work and the low beam is really really dim. Also I have not checked the wires yet
After checking to make sure there is not melted and or corroded connection on the bulb plug, swap the headlight relays and see if the problem moves from side to side.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
not that easy...more than one relay involved in the left circuit and more than one involved in the right circuit.
Could use a volt meter and find out where the voltage drop occurs. With only lo beam, on since might be easier ... less things to check Please keep us up to date. Keith Last edited by kwren; 08-12-2008 at 11:41 PM. |
I had a similar problem with an Outback at my work, check your headlight fuses. (If they aren't obviously blown, and you don't have a test light, swap the fuses with each other and see if the problem switches sides.)
That's my thought, as well. The way the wiring works, with one side out (relay or fuse), the other side is the source for 100% of the lighting. The hi-beam won't work on the one side, and the low will eventually/immediately provide power backwards through 2/3 of the remaining bulbs to light all three up dimly. This, from experience.
Turns out it was just a fuse. Now I need to plug my HID's back in and see if they still work
