possible front diff problem
Ive been having a noise that occurs when making turns at slow speeds 0-20mph . its sort of like a creaking click,click, click. I wasnt worried about it origionally because it hasnt been affecting the driving or making the car buck at all. Could this be my front diff going out or something else? also how do I check my front diff fluid?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Re: possible front diff problem
There is a dipstick for the front diffy, Looking from the front of the car it is on the left side of the diff... The dipstick sits pretty much right on top of the differential
I had that symptom when the front 1/2 axles went bad. Might check for torn rubber boots or leaking.
Gene
id be relieved if it was that and i didnt have to replace the tranny
You know when your front diff is going out when you are driving and you hear a faint sound that turns into what I could only describe as "a baseball card hitting a spoke (card in a bicycle wheel)". You can feel the vibration in the Selector knob.
now this worries me because this is exactly what it sounds like but from what ive read could also be cv joints or axles. doesnt the car buck when the front diff is starting to go??
I dont know if it helps but it happens alot more often during right hand turns than left hand turns
I bought an SVX with a bad front diff and it was a nasty clunking sound going in a straight line. My first SVX had more of a clicking sound when turning hard. I don't recall the direction but turning one way identified the driver's side. As recommended, I went ahead and replaced both front 1/2 axles.
Gene
If its stright line driving then its the diff, if its only when turning probably not. Could be CV joints. The "bucking" only occurs after the pinnion bearing (I believe that is what it is called) is shot
