Bunch of parts if anyone wants.
Hey all I have a bunch of parts maybe it would be use to someone.
-SVX steering wheel - non airbag -30,000kms timing belt and water pump - all timing pulleys, not sure how many kms they have on them but one is bad, I replaced all. No tensioner. - dba 2x front rotors with 1000kms (just because I want the ventilated type) - Transmission resistor, 15ohm 100w aluminium, it already has the holes so all you need to do is bolt on exactly where the other one is AND this one will never break, the standard one is 25W. - timing cover parts, no gaskets. - 3 engine sensors cam, cam and crank. One of them is bad, not sure which one though. I also have a JDM SVX PRND321 shifter with the POWER button BUT reluctant to let go of it because I might use it some day. |
Re: Bunch of parts if anyone wants.
what condition are the timing covers in how much do you want for them ?
mine are cracked around the bolt holes and it doesnt sit on there tightly also wats the transmition resistor do ? |
1991 SVX L JDM 1992 SVX LS-L USDM Last edited by Mike621; 03-09-2009 at 10:01 AM. |
Don't forget to obtain a non-airbag clockspring and column shroud.
Yeah. This hangs as a big maybe, if I do change out the woodgrain in the Ebony, which is on the back burner anyway. I might just go with a USDM WRX wheel to eliminate the woodgrain.
1991 SVX L JDM 1992 SVX LS-L USDM |
Pulleys
Water Pump Spark Plugs with about 30,000kms Timing Belt with about 30,000kms Timing Covers (Top left in pic is screwed) Engine sensors are on the way. Need to take it easy on the money so I'm not swapping out my new rotors for the ventilated type, so they're not for sale. p.s the new Subaru Exiga looks like crap, I can't believe Subaru is not doing frameless windows anymore! Jordan. |
