Re: Car Wont start...... more inside
Well... after all the testing of the voltages, etc.... I knew that wasn't the problem... but she was starting without a problem.... untill this morning.
Knowing that the electrical was good, I did the good ole "tap" on her, and she cranked right up. Huck was right on the money with this one.. and it looks as if I need to get her rebuilt. Thank god there is a good Alternator/Starter rebuild shop in town that has been operating for years that I can trust. Now... where to find the Starter Remove how-to... im sure we have one
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker 2002 Mitsubishi Lancer OZ Rally [Nori] 1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling 1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone) 1992 LSL Ebony Mica (Sold to svxcuseme) |
What Huck says will shake the brushes, to help them make contact if they are worn, but it will also shack the solenoid armature loose so that the reduced amperage that is getting to it, will work it. When the brushes are worn too short for the springs to hold them up, the starter will make a growling noise as the brushes arc on the commutator. The sure way to tell which, is to short the starter spade terminal to the main starter terminal, if it starts, it's the wiring and a relay will fix it. If it does not start, it is the starter motor. PS. Make sure that the car is in park. Harvey.
The above wiring diagram should be substituted for others published to date, particularly as the solenoid and starter is correctly illustrated.`
We still have to factor in the possibility that since the "starting-not starting" is erratic, the "whack-start right up" can be meaningless
Keith |
Time will tell...
Keith |
Look what I found. I had never seen this schematic before because it's in the cruise control section not the starter section of the factory service manual. If you are viewing this soon after I post you may have problems getting the pdf. I'm having packet loss problems and my isp is not being johny on the spot with fixing it.
http://www.ecutune.com/posts/starterCircuit.pdf |
Are we lucky or what!!! If that wasn't the case, we many of us would be in trouble! All this testing and speculative thinking is nice but the Bosch relay install takes a few minutes and we get back on the road again... anytime we want to go! "Time will tell" Keith |
Just wanted to update, the starter finaly completely died, and as a requirement to have a working car for work the next day, I just got a new starter and droped it in.
However, I do plan on going ahead and doing the Bosch Relay, as it is easy, and I mite as well go ahead and get it done now before I have problems with that
One diode grounds the inhibitor relay via the starter solenoid and when the starter solenoid is energised, the relay will in effect be presented with a short circuit. This is apparently part of the interlocking arrangements. It is not possible to ascertain how the overall interlocking system works without access to the CCU internal circuits. The system will be a belt and braces affair. The second diode simply provides the relay with inductive spike suppression.
Cheers Trevor!
Then why are so many of us ending up getting the "click thing" and the voltage drops too low to actuate the starter?? Are you able to test it personally because your car does the same way? Take care, Keith |
Good thread to read.
My car randomly decides not to engage the starter. It even happened to Roo on the way from Cali, and has happened to me once or twice since. A few taps on the starter with a maglite, and it seemed to re-engage. Sounds like a Bosch relay mod, and possibly a new starter is in this car's future. Possibly some new main charging system and supply wiring, and possibly grounding as well... The lights go dim when starting, the turn signals dim the dash lights, and I can hear the turn signal affect the HVAC blower fan speed. But the alternator is new, and the battery seems good. Plus, the headlights are quite dim and yellow, and the keyless remote just makes the car make some 4-pulse thumping sound... but maybe that is normal.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
I am sure you have clean battery cable connectors, right?
Keith |
#28
Because the adaptor; starter interrupt relay when fitted; inhibitor switch; ignition switch; or any of several connections; are in this event faulty; and are presenting resistance. This arrangement also exactly explains the cruise control problem sometimes encountered. No I am unable to personally test for this fault.
#29
If you are asking me, yes, actually it does... the ground wire is not tinned up, or anything, and clamped down on the strands of the negative battery cable, but the terminals are remarkably clean, and not corroded at all.
