fuel pump fuse
instead of unplugging the fuel pump to make it easier to change the fuel filter is there a fuse for the fuel pump? if so where is it located, unless i'm blind its not in either fuse box.
Re: fuel pump fuse
Lifting the rear seat isn't easy to pull up?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: fuel pump fuse
that would require getting out my ratchet set and stuff
Re: fuel pump fuse
but is there a fuse?
Re: fuel pump fuse
There's no tools required unless you count your hands. There is a plastic tab on both side in between the seat and carper that you pull up on and the bottom part comes out.
Re: fuel pump fuse
nope, no fuse.
no subaru i know of has a fuse for fuel pump. connector only.....
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
Re: fuel pump fuse
my friends 05 wrx has a fuse
Re: fuel pump fuse
If you are so concerned pull fuse No. 16, which protects the fuel pump. But why worry? The pump is only energised when the ignition is activated. Keep the keys in your pocket. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Re: fuel pump fuse
my plan is to unplug the pump and start the car therefore draining and releaving some pressure for when i unplug the lines
Re: fuel pump fuse
![]() Fuse 16 also covers the airbag system, but nothing else as far as I can ascertain. Therefore this should do the trick. ![]()
Re: fuel pump fuse
If your pulling fuses for anything airbag related disconnect the battery and wait 10 min before pulling it.
Re: fuel pump fuse
ya you might end up popping the bag lol. Speaking of which anyone know the shelflife of an airbag? I seriously doubt they can last 15years
Re: fuel pump fuse
inspect after 10 years
"Some work occaisionally is fine, but I bought the car for the road, not for the garage. ![]() click here for fuelly mpg info |
Re: fuel pump fuse
