Cigarette outlet not working
My 12v outlet inside the car (cigarette lighter) stopped working. I checked the fuse under the dash and the one marked "Cig/Mirror" is fine. Also all functions of the mirrors still work.
Is there another fuse hidden somewhere just for the outlet? Or could the outlet itself have suddenly gone bad?
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Re: Cigarette outlet not working
You tried multiple devices in it right??
If you have a mechanics mirror you can pull the ashtray and take a good look at the wire connection to the rear center of it to make sure its still on there. After that its just testing for voltage down the line to the fuse block and battery. |
Yep, tested three different devices that all worked in our other car right after.
![]() What really made me think it was a blown fuse was the last time it worked was with a plug in compressor inflating a tire (being lazy and not using the real compressor that was buried in the garage). On the third tire and 10 minutes in, it died. I assumed it was the compressor overheating at the time. Until I tried using something else in the outlet the other day. ![]() Since the fuse at the box is fine, I was thinking there might be a secondary fuse only for the lighter further down the line. But not the case I guess. Have to investigate and probably take everything apart. ![]()
svxcess posted some info on this - about a fusible link on the lighter (he replaced with a wire). http://www.subaru-svx.net/forum/show...hlight=lighter scroll down to svxcess's post
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com Last edited by svxxx26; 09-29-2009 at 05:27 PM. |
It's most likely the fusable link on the side of the lighter itself is blown. I hope you have small hands!
Mike
It is the fusible link on the back of the socket. I am not sure of its purpose since the circuit is fused but my discovery can be found in THIS POST Here is a photo of the culprit: ....... .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Really nice post you did on the cigarette lighter fusible link. Great picture,explains it all.. Just a darn cigarette lighter anyway, who would have known..I'm interested to see if its in the S.M., good of Subaru to think of an overheat possibility and have a safety device in place.
Possibly you can help with my 'no shift from 1st gear' problem. I have it posted, Anyway this was excellent.. I am sure its thanks from many.. M7 |
