Start Issues - worsening
Hi Everyone, I have tried looking through alot of the threads before posting, but now I am more confused.
![]() ![]() I love this car and looks great, I just wish I was more mechanically inclined. Thanks for any thoughts or suggestions. Anna
" To get something you never had, you have to do something you never did." ![]() |
Re: Start Issues - worsening
It is going to be the Coolant temp sensor. When they go bad, the CEL will illuminate and the fans will run all the time (The ECU does not know how hot the engine is so it defaults the fans all the time). Replace the sensor and it should fix the starting issues (the ECU does not know the temp of the engine so it cannot trim the Fuel properly and causes a rich start) If you want, stop down at my shop in Ocean county one weekend and I can confirm the issue and fix it if you want Tom |
Thanks Tom,
You sound very confident , I like that. Also the rich start is something the first mechanic had mentioned. I would love to come down to your shop. If this is something you can do possibly during the week, that would work for me also, since I am off from work for awhile. You can email me at Lonefethr@aol.com with your info and shop hours. Thanks. ![]()
I completely agree with Tom. This is a classic case of a bad coolant temp sensor.
Mike
The contact page our numbers if you would like to call and make an appointment. Its not our main gig so we do what we can on the weekends Tom |
I just picked it up from the second mechanic. He states that they had tested the sensor and that it "ohmed out fine." Still likely to be the sensor? Either way, any suggestions that might make it easier to start in the meantime? Thanks again for all who have taken the time with their thoughts.
I agree it sounds like a CTS problem, but harder and harder starting can be many things. Since yours is a 95, go to the How-To section and pull the code that lit the check engine light...its easy and might confrim the CTS or point in another direction. |
