Re: Vibration under load
Glad to hear...I have the same problem you had. When you took off the old axles, did you see anything obvious that could have caused the vibration?
1996 SVX Barcelona Red 2014 Subaru XV Crosstrek Hybird Touring 2015 Nissan Leaf |
Replacing the axles & ball joints also cured another fairly subtle symptom I was having when cruising downhill at 50-60mph on the freeway. At those speeds, the car is almost coasting, and when the engine would "kick-in" I'd get a little clunk/jerk out of the front end (almost like hitting a very small pothole). With the new axles, that's gone and the drivetrain on the front wheels feels much tighter... Last edited by rlutz; 12-23-2009 at 10:09 AM. |
Update: Problem solved. Thanks rlutz! My front CV axles was the problem. She drives smooth again! I could tell that both axles were loose and tired especially on the inner cv hub.
