Old 01-23-2010, 08:08 AM
Stillhoff Stillhoff is offline
Side panel at antenna
How do I get the side panel where the antenna i mountdt off, so I can install a new one.
Old 01-23-2010, 08:43 AM
Re: Side panel at antenna
Complete instructions (with photos) for replacing the antenna acn be found in the How-To documents by clicking HERE
It's not too difficult to do.
Old 01-23-2010, 08:51 AM
Yes I know that one.
But I want a different antenna and it is very difficult to tighten it from below. So I thought it would be easier to take the side panel off.
Old 01-23-2010, 09:00 AM
dcarrb dcarrb is offline
I've replaced the antenna mast on one and the entire assembly on the other, and it was not that hard, nor costly (assuming you source a used motor/assembly). Don't know what you'd stand to gain by installing something else.
dcb
Old 01-23-2010, 09:29 AM
dcb
The electrical antannas last approx. 1 year here in Denmark due to the climate. When I bought it there already were an aftermarket electrical antenna in.
A original motor and antenna cost $200,- so I have bought a normal antenna I would installe instead.
Maybe I should find a original..
Old 01-23-2010, 09:58 AM
I see. I've never done it but understand it's not easy to remove the "quarter garnish" piece without breaking the plastic retaining pins. Surely there's a way...
dcb
