locking drivers door with key funtion not working
(I did search..)
dont even drive my Svx much anymore, so the battery went dead.. I charged the battery and drove the car around everything worked and ran fine. Parked the car and closed the door like normal (My keyless entry hasnt worked for over a year) so I just lock the door with the key, but this time when I turned the lock to the right, I feel resistance and the doors wont lock. Key turns to the left okay for unlock. Ive never looked deeply into how this system works, so if anyone can give me some ideas, Id appreciate it.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
Re: locking drivers door with key funtion not working
Try some WD-40 in the door lock, then use the key to work it in there. They tend to get stuck if you don't use them very often. Every once in a while when I wash the car or something I WD40 the door locks, so that doesn't happen later on.
More than like a seized actuator
Tom |
okay, what part technically is the actuator ?
think maybe Ill pull the door panel off too and spray some stuff from the inside too.
The actuator is the electric motor that moves the lock. Sometimes they get stuck after sitting for a long time or if something is acting up in the electrical system... (bad alt for example) No cleaning here, just replacement but be carefull I think 94+ has different connectors that the 92&93
Tom |
i need to know this info too
sorry for the tread jack
mine will lock from the key or the lock on the door panel when you lock the driver door it also locks the passenger door when you press the power lock button the passenger door locks and unlocks but the driver does not when using the keyless remote it only locks or unlocks the passenger door anyone have any idea what is wrong with it |
haha jk but honestly, the 94+ cars with the pdl button on the dash may have different ways for diagnostics.
