R1 Concepts Premium Cross-Drilled & Slotted Brake Rotors
anyone using these please review the results? also how about their Posi Quiet Extended Wear Brake Pads...
Thanks, Keith ![]() |
Re: R1 Concepts Premium Cross-Drilled & Slotted Brake Rotors
Guess no one has tried them... They are pretty pricey!
Maybe someone has a good suggestion. Some source that would be better than the original Subaru that have a tendency to warp a bit? Keith ![]() |
They are pretty good. I'm using the premium ones in the front and the regular ones in the rear. EMC Redstuff brake pads and SS brakelines. It all works very well together. I haven't gotten it to the track as yet though.
Thanks for responding! Do the brake pads come from the same source?
Nope. Search EBC's website for the part number and then
![]() The pads that R1 concepts sells might actually be good though. But the redstuff pads kick ass for sure.
I am using R1's house branded ceramics front and back, along with there Stainless lines and rotors I think they are working well together.
I concur that R1 premium rotors and EBC Redstuff are a great combination and are fairly low dust pads. If you don't drive fairly hard, I am not sure I would recommend the pads as they like to be USED! Mainly if you are light on them most of the time, they will glaze over and not act appropriately. Using them somewhat excessively will expose the fibers on the surface of the pad and operate as designed. The drilled/slotted rotor helps keep the pad conditioned and the surface flat in my experience.
Hope that helps
- Sonny [1992 LSl, Claret 160k] / [1992 LSl, Dark Teal #378 172k] / [1992 LSl, Claret 150k] / [1992 LSl, Liquid Silver donor] / [1992 LSl, Liquid Silver 4.44] / [1997 LSi, Polo green #089, 150k] 1992 Chevrolet Lumina Z34, white 35k miles ![]() 1992 Chevrolet Lumina Euro, charcoal grey >200k (first car) 1992 Chevrolet Lumina Euro, charcoal grey >200K (for sale) 1986 Honda VF500F Interceptor 1994 GMC Jimmy S-15 |
It does!
Thanks... Keith ![]() |
Yeah ill back that 100%. Turns the spongey mushy jello brakes into real boy brakes.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
how easy is the lines to replace. any how to's?
They aren't that hard, but honestly I'd have a shop do it just because it's not that expensive and brakes are kinda super important. Plus bleeding brakes is a pain and many shops have vacuum pumps that make it easier.
so easy that reading "how to's" would take up too much of your putting it up on jack stands, unscrewing the ends to take the old lines off the new lines on, one at a time, being careful to get the old flat copper washer seals off and out of the way and the new flat copper washer seals correctly placed on each of the new lines as you bolt the end on, and your bleeding the system time!
All that considered, a "how to's" might be a waste of time. Keith ![]() |
Keith ![]() |
Very few people have compressors at home. And odds are if you have your own compressor, you're not the type to need help changing brake lines...
