where could i find bearings for wheels
my car is making a noise while i drive and it's not the rotors or break( i replaced those) im guessing it could be the bearings?
Re: where could i find bearings for wheels
if you need bearings, contact: jackie.whetzler@annapolissubaru.com.
bought mine from her, she was super nice and gave me a great price on them + fast shipping. ![]()
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
You can also do a search on Ebay for "Subaru SVX wheel bearing".
Lee
Timken part number TM516003 is a cheaper alternative that has worked well for many people.
When you have the wheel bearings changed (regardless of brand, OEM included) make sure that the shipping grease is changed to actual wheel bearing grease. Mobil 1 synthetic grease works well. You can use brakleen to get rid of the packing grease. Many shops (dealerships included) are lazy and do not do this. You also need to ask them to not overtorque to axle nut when they put it back together. Be insistent if they are lazy or you'll be changing them again in as little as 10k miles.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
you can go to napa and get them, i got my job back for the summer they are like 77 thank god for cost +10 for parts
how hard is it for me to install them myself?
You need a lift and equipment specific to changing wheel bearings
Special Thanks to Our Friends and Sponsors: * ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
ok what type of equipment?
This is the best price I have found:
http://www.discountautoparts.com/Sho...+Seals&mode=PA Anyone find a better price?
Just found a better price:
http://www.hubbearing.com/ShopByVehi...=True&rewrite= And shipping is only $5. And for even less you can go to rockauto.com and use the discount code 56588744072636. The price ended up about $48 for me.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 05-18-2011 at 10:00 AM. |
are these good in quality, or does
it not matter in bearings r they all the same...? |
So far, I haven't heard of anyone having a problem with any particular brand.
Is "national" the same as NTN?
I got my bearing from rockauto.com. Inside the Timken box was an NTN bearing. Does NTN make the bearings for Timken or is there something fishy I should be talking to rockauto about?
