#226
That's a pretty tall effort to try to convince people it's not a Subaru!
#227
Oh, your SVX leaks? :P
#228
Did the front brake pads today, easy enough... but wouldn't have had to do it if the previous owner didn't use cheap pads and some really wrong grease for the sliders. 0 grease left in the ones with the bolt and one of them was starting to stick bad, causing the pads to drag on that side.
On the wheels, turns out they fit fine without spacers, I was just being weirded out by the different center section. Quick trip to the store was weird having 4 tires that were round, balanced, and had grip. Its now telling me to spend lots of money I don't have on suspension... |
#229
Right there with you, man. I blew about $6000 on repairs this year so far. Could have had Konis, glass hood, and a full exhaust setup by now.
The car however does feel supremely legit at this moment. Money well spent.
#230
yes i would usually not worry about it but the cam seal is pretty much toast and ive lost a lot of oil in 140 miles ive put on it lol |
#231
I got a comment from a woman yesterday whom said: "I've never seen that design of Subaru before", and upon being informed of its age she proceeded to admit that "they should have kept it".
I gave the car a little workout today. The LGT gears make better use of its balls and I totally recommend the swap for anyone with a 5mt. Could use a little more torque though. Going uphill from first is a little more challenging. Something else worth note: The Competition Clutch stage 2 kit feels very comfortable, but the F1 Racing stage 1 I had has way more bite. I've burned the clutch in 1st about 5 times already because I gave it a hair too much gas. It's not anywhere near as jerky as the F1, though. Worthwhile trade-off.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 05-20-2011 at 02:19 PM. |
#232
Also, I wonder how the STi clutches compare to the 5 MT ones. I have an OEM style or maybe stage 1 exedy clutch and it feels very grippy, but also pretty comfortable. I have burned it a few times though, and not on purpose.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 05-20-2011 at 03:03 PM. |
#233
The pull type clutches of the WRX/STi are better than the push type in the 2005+ LGT 5spd.
I personaly found the gearing of the LGT kinda annoying in an actual LGT. 1st a little tall, 5th alot short. Not as annoying as the 4.44 Forester XT gearbox though. The 07+ STi 6spd has my vote for best off the shelf gearbox, but it of course comes with a cost, weight and power penalty over a 5spd. |
#234
LGT versus WRX, only 1-3 are taller, 4-5 are the same.
Personally I felt the WRX gearing is annoyingly short and doesn't take advantage of the wide torque band. 1st is a little tall, but I cruise around in parking lots so often in 1st its perfect once I get moving. I don't think ill be taking it to the drag strip though unless I start making 30 or so more lbs/ft.
#235
So today I replaced the lever on my SVX. The lever is the piece that connects the sway bar to the sway bar end link. My GFs brother and I did it in the driveway. We jacked up the front end took off the drivers side wheel and undid the 2 bolts that hold it on. The one that held it to the sway bar was real easy to get off, mainly cus it was covered in oil and not rusted. The endlink bolt was a little rougher, but some PB blaster, a wire brush, and some vise grips fixed that ... And then we just reassembled. It fixed the one of the problems I was having but I need to still change a few more things and then it will be good to go.
Jared 1992 dark teal SVX LS |
#236
re did the stereo in the svx, took the 2 2 channel amps out and replaced it with a 4 channel amp, then replaced the 7x10's with some eclipse 6x9's and a 10 inch sub with built in amp. then sound deadened the parcel shelf and doors. here's the left one.
#237
I know it's a little late, but I had wash N waxed my cars for Reading Friday afternoon. Then I didn't get to go. I also detailed the interiors and fixed my broken window switch (finally). Phone pics follow....
Next time I get a chance I need to detail both engine areas. Killer Tomato still needs some cosmetic engine attention after the whole Optima Battery issue.
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
#238
Drove black today. He also required $68 of fuel. TH
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
#239
Scrubbed the dirt off my exhaust tips, scrubbed my summer wheels and installed/aired them, found the clanky noise in the end links, finally finished the other half of the 15 minute mod, put on my engine aero panel.
#240
Put the motor from my wrecked pearly into my blue car. Mostly, anyway. Just got home (6 AM here). Sleep for a couple hours and then to the lab to do more work...
The motor has like 70 something thousand miles on it, and has been spruced up some with a set of LAN's cams. Should be driving in less than a week.
