Alternator??
I just bought brand new battery and battery ends for my car and it still only charges at 11.7 volts when i drive and dies down when i stop. whats the issue? is my alt. taking a ****?
Re: Alternator??
Based upon your information, I would say that your alternator is definitely on its way out. Normal charging voltage should be in the mid-13V range or higher with the engine running. At 11.5V, the alternator ceases to charge the battery.
Is it the original alternator? Are all of the battery cables, including the ground wires, cleaned and securely tightened? Do the idiot lights in the dash glow dimly while idling? Is the alternator belt tight? Anyway, the cheapest and best source for an SVX replacement alternator is HERE After you return your old core for a $60.00 credit, your final price is only $89.00. The core return is paid for by the company and the new alternator comes with a 2 year hassle-free warranty. If you order online or by phone, mention the coupon code 4747 for free ground shipping of your new alternator. If you call, speak with Christian. This company is the best!! .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-10-2011 at 11:04 PM. |
Re: Alternator??
Could possibly just be the crank pulley separating. The test for that is free: http://www.subaru-svx.net/forum/show...72&postcount=4
Re: Alternator??
Mark your pulley and drive it around for a while.The marks should stay aligned. Lower photo for reference only; the lines could be at any distance from each other indicating that the front and rear parts of the pulley are not securely attached to the rubber separator between the two .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-11-2011 at 09:16 AM. |
Re: Alternator??
everything is tight. looks like its time for a new alt. thanks for the help
Re: Alternator??
Where were you measuring the voltage from? Was the engine at idle? Did the voltage change with RPM? Can you find a place that will check your alternator for free?
Re: Alternator??
If you remove the alternator from the car, Autozone or Advanced Auto will test it for free.
Re: Alternator??
If your alternator output is fluxawating, as they sometimes do, charge great and at other times, not charge so good, taking it to get it tested wouldn't necessarily help you at all. You have pretty much nailed it already as you do not have to increase the rpm to get more than 12 volts if the alternator is working. Your 11.5 is undoubtedly the existing battery voltage. Keith ![]() |
Re: Alternator??
From past experience, I had my alternator tested off the car and they were fine. But when it was tested in the car it was bad. It was bad connectors!
Re: Alternator??
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty ![]() ![]() 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 ![]() 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
