Flashing power on dash
Even now and then then green power light comes on but it's flashing?
Re: Flashing power on dash
You need to go to the how to & faq section to find how to pull codes from the TCU. Your TCU is telling you that it is having an issue.
'92 SVX LS Pearl White - 6mt |
On startup or while driving?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
It only has happen on start ups
Then yes, you have a TCU trouble code that you need to check. This will help: http://www.subaru-svx.net/forum/show...13&postcount=2
