Extensive work done to my car
My 97 Ebony has been at OT's since 9/14/12 getting tons of work done to put it in the condition it should be. Here is a rundown of whats been done so far.
MAINTENANCE REQUESTED: Replace head gaskets (customer parts) Replace timing belt and idler pulleys (customer parts) Replace water pump (customer part) Thermostat cover modification Replace thermostat (customer part) Oil pump modification Reseal engine with new gaskets Replace Vacuum/ PS/ ATF/ Coolant hoses Replace PCV valve Replace I.R.I.S. valve Replace spark plugs Replace P/S idler pulley Replace A/C idler pulley Replace knock sensor #2 Replace 6 coil packs (customer parts) Replace emissions valve Replace front and rear brake calipers (customer parts) Replace front and rear brake rotors (customer parts) Replace front and rear brake pads (customer parts) Install stainless steel brake lines (customer parts) Flushed, refilled and bled brake system Valvoline DOT 3/ 4 15 minute suspension mod 20 minute suspension mod Oil change and oil filter Replace front and rear swaybar bushings (customer parts) Replace steering wheel (customer parts) Replace transmission shift handle (customer part) Replace main cat Magnaflow 94007 (customer part) Replace exhaust resonator Replace 3 oxygen sensors (customer parts) Install O2 bung for 3rd. sensor Check crank sensors/ Cam angle sensors for proper operation Install HID fog lights (customer parts) Replace broken transmission pan bolt Repair dented transmission pan
1995 POLO LSI 76K MILES SOLD |
Re: Extensive work done to my car
That's quite the work order! Good on ya, and best of luck to getting her back on the road!
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) |
When were you going down to pick it up? (Assuming it is ready.)
Mmmmm lots of upgrades and repairs.
All I see there is $$$...
BUT you saw it today and commented on how nice it looked.
Did you get my email?
will be picking it up within the next few weeks
your right, i really like that color. she looked totally worth it.
Great job! These cars are worth every penny you spend on them.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
