Fiberglass hood and hood struts
I just bought Rebecca's old fiberglass hood (I love it, thanks Rebecca
![]() Now, I have replaced the OEM struts with some aftermarket ones as outlined by Jon's instructions and they have been working perfectly on my old hood. My question is, can I drill holes into the crossbeam (for lack of a better term) on the underside of the hood to attach the hoodstruts? With the entire thing being fiberglass I wasn't sure if that would be too much strain on it and break while trying to close the hood. Does anyone have any experience on this that I could benefit from? Thanks
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Re: Fiberglass hood and hood struts
I think that to be safe, you might get a hood prop like what comes on Outbacks/Legacys.
I am not saying that its not possible, I am offering a cheaper alternative, with less chance of failure. ![]()
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
PM svxfiles. He has a lot of experience in this area.
A set of worn-out stock hood struts would be sufficient on the lightweight hood A mini vise grip on the shaft in the open position would help if they weren't strong enough
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
It's the chance of failure i'm worried about lol. I honestly like having working hoodstruts again and I would like to keep using them. These do seem stronger than the OEM ones though so I could see it causing an issue with the fiberglass hood (snapping it in too the first time I try closing it is my biggest fear the) Maybe I could buy some weaker struts (same dimensions as these) to use on it. It wouldn't take but a minute to swap the mount onto it now that I've already done it once. Any thoughts?
I remember looking at Young Tom's Shadow Machine at Reading and talking about the hood with him. He told me he used a set of worn out hood strut on the fiberglass hood. A set that would fall on a normal hood was perfect for the lighter weight of the fiberglass. I might still have my old set if you want them.
I'm in a situation similar to yours. I have a carbon fiber hood sitting in my garage, and the hood struts on one of my cars no longer hold the stock hood up very well. I am going to give those a shot and see how it goes, and if they seem too strong, then I'll probably go the hood prop route.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
I made a really nice hood prop for the Killer Tomato when that hood was on the car. It's nice to have hood struts but I'm fine with just a hood prop. I don't know how many times the hood on my claret would randomly fall (sometimes on my head! I hear concussions are easy to get!). Glad you like it!
Rebecca 92 Claret SVX LS-L (180k) 09/91 #5,732 06 Suzuki Boulevard M50 7k 68 Cadillac Coupe DeVille (70k) Storage/hibernation for now. Past SVXs: 94 SVX Emerald Pearl FWD (Sold) 96 SVX Bourdeaux LSi (Sold) 92 Pearl SVX LSL "Stay Puft" 5MT (140k) #148 (RIP) 95 Brilliant Red SVX LS (162k) 12/94 #564 "Killer Tomato" (RIP) |
Ok, took some measurements and the fiberglass hood is 22lbs. The stock hood is right around 45lbs.
When I did the new struts I got the GNSI 2250-90's which seem to fit pretty well. The hold 90lbs with an expanded length of 18" and a compressed length of 11" They do have struts with the same dimensions that are just weaker. They have 30lbs and 45lbs (http://www.spdhardware.com/catalog/G...20Gas%20Spring) I'm thinking I could do one of those. That would exert less pressure on the hood when closing it, but still be enough to hold it up. I'd probably go with the 30#'s. What are your thoughts?
