Need part number EG33 cylinder head piece
Hello all,
Currently rebuilding my EG33 and one of the hydraulic lifter LINERS was damaged so the machine shop removed it. They couldn't get it through their suppliers so I am going to attempt to order one from the dealership. Hopefully it is something sold separately and not just with a complete head. If anyone knows the part number that would be most helpful. Yes I have contacted the dealership, still waiting to hear back. Opposed Forces parts catalog didn't show it either. Need this liner: ![]() Missing here: ![]() For reference: ![]() cheers -Evan Last edited by neverLift; 04-21-2013 at 08:38 AM. |
Re: Need part number EG33 cylinder head piece
Any luck getting info on your part?
Contact Jackie at Annapolis Subaru. She knows the SVX and should be able to ship to Canada. (888) 851-5976
Hahaha I didn't even see that face! Hilarious.
Thanks for the tip, I'll give that a shot. cheers -Evan |
Evan, I'm looking at the parts diagrams now, and I can't seem to find this. I think it may be part of the head.
I'll take a closer look on my lunch break and hopefully have some more solid information for you. -Jim (Subaru dealer Parts Guy)
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX 1994 Legacy GT 2001 Forester 2002 Impreza WRX 2005 Impreza WRX STI Need parts? Last edited by Subachouli; 04-23-2013 at 11:30 AM. |
The engine parts catalog doesn't show any such part.
Thanks for the help guys, as I expected it is a part of the head. I should be able to machine something up that will work.
cheers -Evan |
Someone here has to have a bad head you can harvest from, try the parts wanted section.
Or you could ditch the hydraulic valve lash adjusters and stock valves and get some aftermarket valves and springs like RallyBob did.
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
He'd still need the HVLA liner.
Although that is the plan for a future set of heads I would like to build, just want to keep the engine stock for now. And as stated above its the liner not the HVLA itself.
Thanks guys for the input, I've got a WTB posted if anyone knows of some heads that could be sacrificed. Worst case I just take some measurements and make a CAD model to get one machined. cheers -Evan |
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) Last edited by EdWindows; 04-23-2013 at 09:15 PM. |
