Losing Brake fluid
I've been losing brake fluid on one of my SVX's, but can find no leaks anyone else have this issue, and find the culprit?
I've replaced the master cylinder, and searched for signs of leaks, but have found none...
Re: Losing Brake fluid
How fast do you lose it? Can you park the car, pump the brakes and empty the reservoir?
If it's not around one of the wheels, my next guess would be the lines around the fuel tank
Sometimes I can drive for days without noticing it, and sometimes it goes pretty quick....never find any wet areas, and this is a southern car, with no rust, I' really don't expect it to be the lines over the tank, but even if it were, it should be leaving a puddle...
Thats what I was thinking, but he replaced his master cylinder.
Look under your car right where the lines go under the rear passenger seat to the underneath of the vehicle. There's a little "intersection" that the lines go through before going over the fuel tank. Mine was leaking but no fluid would show up anywhere, and that's where it was coming from.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
And Harvey, that should be ruled out, since I've replaced the Master cylinder....but I did pull off the vacuum line to double check, and it is dry inside..
I would try putting cardboard under each tire while it is parked and pump the brakes. I had a small leak in the rear and it would never leave a wet spot on the ground except until I used a cardboard. Try it.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
It ended up being the left front rubber line to the caliper...wouldn't leak all the time, but would under the right conditions....Got a new one on the way...
