security system problem
I can't seem to get my alarm system to go in to program mod so I can program a key fob. I have the original paper work and I'm sure I'm doing the procedure right but it won't enter program mode. Any advise?
Party like a rock star, rock it like a porn star, and drive it like you stole it. Life's short, live it |
Re: security system problem
The part where you push the security button over and over - try doing it at a different speed, probably faster. I think the buttons get finicky over time, and don't register every press. So you just kind of have to keep trying until you get lucky.
You're following this procedure, more or less, right? http://www.subaru-svx.net/forum/showthread.php?t=58773
Yea I've done it that way. I even unhooke the battery to see if it would reset. I turned the alarm on and test it to see if it works and it does. I'll try to clean the contacts on the security button
That helped and I got it to work! Thanks dude. Does anyone know the difference between the two button remote and the single button remote?
It does not have a separate signal for locking and unlocking like the newer cars. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
Congrats on fixing it. The 2 button remote works the same in the SVX as the 1 button ones. After a while, they switched to the 2-button one, so it would be the same part as the legacy, just with a different sticker on top. The SVX security module responds to both buttons the same way - locks if unlocked, unlocks if locked.
Thanks for the help guys.
