Sometimes starter clicks but doesn't crank
Sometimes when I start her the starter will click when I turn the key, but it won't crank. If I turn the key off and on again enough times it will likely fire. It's almost as if the starter is beginning to seize up. Has anyone else had this issue? is it likely the starter going bad or could it be a wiring / grounding issue?
92 SVX LSL - 231k (SOLD!) 97 Legacy Outback - 227k 04 Porsche Cayenne S - 99k 95 Ford Ranger - 220k |
Re: Sometimes starter clicks but doesn't crank
You might be able to do the starter relay mod mentioned in this group and the other group
http://svxworldforums.com/view_post.php?post_id=35308 and http://www.subaru-svx.net/forum/show...=starter+click |
Wow! You go girl. God job.
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
