Cruise control
Have not had my car out on the highway for a while and went to Canberra yesterday - to my surprise I found that my cruise control was not working at all. It just seems the switch has gone dead.
Has anyone had any experience with this and what should I look for first. Just as an aside almost got home and started having a major knocking sound when braking as if the whole engine was going to fall off! Found this morning that the rear control arm lost its lower bolt and the real wheel was able to move in a horizontal position resulting in major knocking sound - all fixed now with a new bolt! |
Re: Cruise control
Sometimes the vaccume line comes off of the control. Check around where the wipers are and find the hose for the vaccume and make sure it is connected. I hope that is the problem - easy fix.
Re: Cruise control
Same here, but mines the switch itself. It powers on if I hold the switch in a few millimetres, but it doesn't click on/off.
So don't discount that as a possible issue too. |
Re: Cruise control
Thanks Ensteele - spot on! That was the problem and easy fix!!!
Re: Cruise control
My hose is on, cruise light comes on but no cruise worked one day not the next. Help
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: Cruise control
Could be the brake switch sticking. Does the light come on?
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Re: Cruise control
@Conn Svx...are you talking to me lol
Re: Cruise control
Bump
Can anyone help? Still having problems with my cruise. Hose is in, light comes on bit no cruise
Re: Cruise control
Could be the brake light switch. Check the switch on the brake pedal
Re: Cruise control
What has the brake switch light got to do with cruise control ???
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Cruise control
Touching the brake "disengages" the cruise control though it stays "on". I understand the disengagement is activated by the same switch on the brake pedal assembly that turns on the brake light went you press the pedal. If that switch is stuck it could keep telling the cruise to "disengage". A simple test may be to have someone watch your braking lights on the rear of the car while you press and release the brake pedal. |
