Circuit to run radiator fans after shutdown to avoid heat soak?
Hi all,
Would like to add a circuit to run radiator fans after shutdown to avoid heat soaking the engine compartment wiring, etc. Has anyone here done this?
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: Circuit to run radiator fans after shutdown to avoid heat soak?
http://www.at-fairfax.com/P1786-ELK-960.htm needs an activating button http://www.naxja.org/forum/showthread.php?t=1004656
"Peace is the flower of justice." |
I'm sure you would do well with a basic turbo timer. It will allow the engine to run at idle for a predetermined amount of time after the ignition is shut off. This will probably be a lot easier and more efficient
Tom |
