calipers front rotors
Hi All
Does anyone know if there are renewed or new calipers for sale? The right front caliper is stuck and gives enormous heat I would rather change both of them Thanks Rinus (the Netherlands) |
Re: calipers front rotors
I'm quite sure: http://www.rockauto.com/ will ship to The Netherlands.
I've bought a lot of SVX parts from them including brakes. |
Centric makes re-manufactured. I have them on my car and am happy.
http://www.centricparts.com/ They don't sell direct, so you'll have to find a dealer. They also do repair kits. Caliper Kits Brake Caliper Repair Kit AWD Front 143.42017 2ea Caliper Kits Brake Caliper Repair Kit AWD Rear 143.47007 2ea Caliper Piston Steel & Aluminum Caliper Pistons AWD Front 146.43006 43mm Piston 4ea Caliper Piston Steel & Aluminum Caliper Pistons AWD Rear 146.38014 38mm Piston 1ea Calipers Posi-Quiet Loaded Caliper AWD Front Left 142.47016 1ea Calipers Posi-Quiet Loaded Caliper AWD Front Right 142.47015 1ea Calipers Posi-Quiet Loaded Caliper AWD Rear Left 142.47506 1ea Calipers Posi-Quiet Loaded Caliper AWD Rear Right 142.47505 1ea
That is awesome information. Thanks!
Thanks everyone
Rinus |
Could you tell me the name of your dealer? Thanks Rinus Holland |
They are in California USA. I'm sure there must be dealers closer to you. http://www.appliedrotortechnology.com/ Have you tried some of Centric's "E-tailers" ? http://www.centricparts.com/tech-sup...9285&x=64&y=27
Pretty sure eBay has them available, no ?
Thanks boys
One more question at ordering from the US Are the brakes in Europe the same as in the states?? Rinus |
