More aggressive cam
Hey guys anybody know if Porsche per say has a cam that'll work with the eg33
Cheaper alternative? 96 Ls-I Polo Green - #467 - |
Re: More aggressive cam
Absolutely Nothing from a Porsche will fit in a Subaru EG33.....
Damm so no such luck on cheaper alternatives to a more aggressive cam profile
I'm from massachusetts they don't work with their hands so much as in machining things as the older days or it's super expensive Goal is a N/A 300-350 whp car close to stock looking as possible Would need stand alone computer Wrx injectors Equal length headers Poor mans cam options? Mainly intake Gonna want to re seal and ring the whole motor for peace of mind Money will be spend on that and the computer mainly |
And doesn't a Porsche 944 tall boy oil filter fit the svx over the standard short can
Any decent machine shop can build you a reground cam, if you give them the specs you want. There have been a few member that have built EG33's, maybe one will chime in with some recommendations. There is more activity on the Facebook site if you get on there.
I have been using the 944 oil filter for years. A direct fit. Maybe false security but, the stock one is so small.
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) Last edited by bwb3; 03-31-2018 at 05:41 PM. |
This years goal is just a healthy daily |
Oil filter to fit Porsche 944 is $4.99 at Autozone. Low budget cam mod from way back was to use SVX exhaust camshaft for intake. Exhaust has 8mm lift compared with 7mm on intake. I had this for a while on my '94 emerald, but can't say that it made that much improvement. Was never dyno'ed. From personal experience can say that 300-350 whp N/A is not achievable. Young Tom got 246 whp on the emerald, and that was using about every trick in the book. Even so, idle was lopey, had to let it warm up for a while, before leaving the garage, or it would stall, and it failed emissions. But with the hammer down, it is a screamer. All of these are characteristics of high lift, long duration, big overlap camshafts. Look at my signature, below to see all of the things that were done to the engine. If you can think of anything more, let me know. I might do them.
By the way, this is not an inexpensive approach. Engine alone was probably between $20,000 - $25,000 before it was all over. Turbo is probably cheaper for more hp. Just need to get the CR down a bit. I've always wondered if there were some extra material that could be removed from the combustion chamber in the head that would drop the CR down a point or two to allow more boost.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold Last edited by shotgunslade; 04-16-2018 at 12:20 PM. |
No. ECU chip MOD OR Stacker ignition ?
Is the HP ratting WRP. Or FLY WHEEL HP ? I also heard the ECU. Can't Handle much more than 20 extra HP
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 04-17-2018 at 12:42 PM. |
I think it is the MAF that can't handle much more HP
Hydra Nemesis stand alone. No MAF. Dyno-tuned using a laptop, controlling fuel, spark, using input from the wideband O2 sensor. WHP. Use the search function and pull up the chart from my pull. Posted it 7 or 8 years ago
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
The Male brand for a tall boy 944 filter which is OEM on Porsche cost me 26.99 in Massachusetts
It is supposedly better for oil drain back on colder starts I am way more interested in OEM tune-up factory setting condition Re- sealing and bearings for the motor maybe upgrading and cleaning internals along the way before I even contemplate HP or Body and Paint Car runs no engine light, has a real clean body with some fatal frame rot in the rear SSP hooked it up with an entire rear suspension so there's no messing with frozen crap Aside from gettin in back out there I may only mess with the exaugsht before I have real money |
Maf upgrade would have been needed for 300whp anyways on a good stand alone
Wrx injectors should be able to accommodate that Throttle body as well but it opens the intake question And weather the vale train would allow it |
Hydra Nemesis stand-alone doesn’t use a MAF. Read this thread: MOD Mania>Proven Engine Enhancements>11:1 CR Race/Street Engine build
Also there was a 318 WHP EG33 build in 2.5RS coupe. I rode in it at Watkins Glen. Awesome but totally unsuited for the street. Jack Laverty built it at EFI Logics. With a Motec ECU. Go over to NASIOC and search it there. It’s gone now,Jack parted out the car. Too much money. RallyBob build the heads for it, also. He suggested that individual throttle bodies could have added another 30hp. More $. Speed don’t come cheap and you can’t just bolt it on.
