Stevebsy's 5MT swap thread, Start date 8-4-2019
Finally I'm making some progress.
Just picked up a 06 Saaburu 2-5X Aero with hail lumps and a 3 cylinder engine last night. This is great because I'll have every part I should need to make this happen! The transmission is the 3.7 ratio w/ .738 5th gear ratio, so it should turn about 2768 at 75 MPH. Let the fun begin! https://www.dropbox.com/s/l622npnp74...2108a.jpg?dl=0
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 08-04-2019 at 02:02 PM. |
Re: Stevebsy's 5MT swap thread, Start date 8-4-2019
Unrelated, but is it just me or the front left wheel has a chunk missing?
Looking forward to seeing it finished!
Wheeeeeeee
just a year later update: 5MT is in car, attached to engine Pedalbox is in Engine was resealed, new HG, etc.. when I had everything out. Tonight I got back at it again after a long absence and started reconnecting the engine accessories. Remaining items: MT trans. mount fabrication Extend shift rods Remove AT shifter, install MT one Hook up and bleed hyd. clutch Sort out wiring mods required for NSS, etc.. Build new exhaust system to replace currently hacked together one. Since one seat is out, remove the other one, then pull carpet and power wash so it isn't so nasty. 30th anniv. meet should be attainable lol
Progress! Great to hear.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
Update-
Shifter linkages extended today, took a couple tries to get it perfect and centered in the AT shifter trim opening.. Picked up a 2000 Outback MT drive shaft, so that will save a lot of work as it supposed to bolt right in and work. Tomorrow will finish weld the linkages, paint them, then look at fabricating the trans rear mount. I've got the parts from the donor car, hoping I might be able to use them to reduce fabrication, we'll see....
You're getting there!
Yee ha - almost there...
Today: Swapped LSD into 3.7 rear diff. Somehow got the shims messed up, so I had to do the math of the FSM to the best of my ability. Didn't know how to figure out the Dimension E/F though. Got the backlash dialed in between .1 and .2mm per spec. (~.12) so I think I'll be ok....? Hope so Installed 2000 Outback MT drive shaft, fits perfect Finished installing my Trans mount for the rear. Mine is different to the 'standard' style one, but I think it'll work. Some uuuuuuuggggggly welds on there but it'll hold I'm pretty sure. Finished the interior trim install around the shifter hole. Just need to modify the skirt thing a little bit to fit better inside the SVX cutout. Attached up the slave cylinder and reconnected the brakes master cylinder Attached the front exhaust section (manifold + resonator on each side) for some brief testing. Debating taking it to get a whole new system made up, or just patch what I have back together.. Tomorrow; Alternator wiring upgrade Reconnect engine harness Reinstall radiator, heater hoses, fuel lines, Bleed brakes & clutch Fill fluids - engine, trans, diff, brake, clutch, coolant Helicoil for starter bolt I'll get some pictures tomorrow but hope to make vroom vroom noises by the afternoon
Fantastic!
Vroom vroom?
Yea nice vroom vrooming
Sounds good with just the first resonators hooked up Let it idle for about 10-15 min, got to temp, no gushing fluid leaks, nothing on fire, seems good. Still got a few things left: Replace leaking trans output shaft seal Extend VSS wiring Run NSS/Reverse wiring from trans into cabin, into 4eat plug Run clutch switch wiring into 4EAT plug (same one as NSS) Bleed Brakes Replace DS Front CV axle Install shifter trim boot Reinstall enough of the exhaust to get it to a shop to redo a new one Get it registered again
Hope you get it up the the Dragon Meet next Year!
