Old 02-23-2003, 08:44 PM
4wordSOUL
Question what do i need to check?
I'm thinking of getting a '94 with 90k on it, what problems should i ask the mechanic to check for? and is there a way they can see how the tranny is doing, i drove it and it seemed pretty tight, not loose at engagement or when i accellerated. thanks.
Old 02-23-2003, 09:15 PM
MNYPNNY's Avatar
MNYPNNY MNYPNNY is offline
FKA....thndrmtn92svx
Alcyone Silver Contributor
Send a message via AIM to MNYPNNY Send a message via Yahoo to MNYPNNY
Yea! Another one in Colorado!!!!
Make certain they check out any slippage in the transmission.
Also, the most obvious problems are wheel bearings and warped brake rotors.
~~Michelle
~~Michelle
'92 LS-L - copper - 190K miles
'94 LS-L - pearlie - 92K miles
*still have '92 parts*
Old 02-23-2003, 10:09 PM
JLittell
Welcome 4wordSOUL! I too have a '94 with 89K. Most of the quirks were fixed between the '94-'97. These cars are pretty reliable.. Buy it!, and get registered on this Network!
Old 02-23-2003, 10:58 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
If you have a member near you, ask him/her to check the car out for you.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 02-24-2003, 01:36 AM
SVXdriver_007
Feel free to learn from my mistakes.
1. If you smell antifreeze its probably got a leak.
2. If the person you bought it from has installed lights onto your side mirror then the mirror probably doesn't work anymore.
3. if the person you are buying fom has made a custom exhaust by cutting out the resonator, and painitng the muffler red walk away...who knows what esle they did.
4. Test everything it sucks to be half way home and discover that the wiper blades are improperly installed, especialy when its raining
A few other things to check are,
1. Smell the tranny fluid if it smells burnt...it is,
2. Take it for a drive then check the wheels for heat on the rims if the bearings are bad they can heat up the rims
3. Test everyhting electrical.
probably the best thing to do is find a member near by and ask them to look at it, Like Seraph said, take it to a garage have a Mechanic give it a look-over it may cost you a few bucks but could save you in the long run.
Welcome to the Forums, I'm pretty new also but so far everyone is really cool, and this place is an excelent source of info.
Shane
Old 02-24-2003, 06:26 AM
svx_commuter's Avatar
Shane
Good points you have here. I was wondering about this one though. How do you separate bearing heat from brake heat? Will the rims get hot just from stopping?
John
Old 02-24-2003, 07:58 AM
wawazat??'s Avatar
wawazat?? wawazat?? is offline
Yeah, I'm still around
John
I don't believe you can separate the two John. The wheels will definitely get hot from braking. Have you ever washed your car right after a drive? Water vaporizes when it sits on the wheels.
Todd
Down to none
Old 02-24-2003, 07:47 PM
SVXdriver_007
Todd
But that would depend on the amount of braking your doing take the car on a dip up the road no heavy braking, try to go in a strait line where you wont require to much braking. Its not the most scientific method but it can help.
