What Is This For??????
The previous owner of my SVX told me it was a 'switch' for the window's. Everyone that I have talked to said it wasn't. So...Tell me, What is it, and where to put it????
~Deja~ |
Those look like the snap ins for the side panels of your interior. I remember seeing clips that look like that when i took off my rear inner panels.
Well, my passenger side window won't roll up or down from that door. So I took off the window switch thingy, were you see the little bottons that make the window work. If I push on those real hard, I can roll it down, but not up. So... Whats wrong with my window? And does that part fix the problem, or has it another function?
~Deja~ |
It sounds like the motor is functioning, you probably need to clean your switches with some rubbing alcohol and letting it dry. Check your switch with a multimeter to make sure theres power going through it. But if you need to push hard for it to work it sounds like a sticky switch
I should have the how-to in my locker. If not, I'll re-do it again. But give me another weekend. I am going to be partying this weekend.
L
Do I have to take the door panel off to do this?
I will try to figure it all out. Thank you for your reply! ~Deja~ |
L
Thingy
The plastic part you show appears to be from a door panel. These little gizmos fit inside the door panel between the first and second lip. The protuding portion snaps into a hole in the metal door skin. There are seven of these for each door. Good luck with your project.
