rear end
ah oh.......looks like my rear end is going.
Any suggestions? Is it something my husband can do? He wants to know if it is possible to pull the U-joint and tighten the pinion gear. I heard that the U-joints have to be cut off that they are integrated with the drive line....is this true? AAACCCKKKK!!!! ![]() |
Can you give us the symptoms? It may be a bushing rather than a diff problem.
Here is a good exploded view of the diff: http://www.subaruparts.com/diag/?mod...category=195-A The flange plate is torqued to the pinion shaft at 125-146 ft lbs so I severely doubt it has loosened up. As for the driveshaft, it unbolts from the diff via four 12mm bolts and nuts. The driveshaft is not serviceable, but you can take it in and have new yokes welded on that accept replaceable U-joints. My last one cost $239 to be converted to replaceable U joints. Hope this helps. Doug
Re: rear end
Stephen
92 Ebony - Level 10/n2o REAR-ENDED 92 Teal - painted yellow/4.11 5spd/n2o SOLD 92 Claret - 4.44 SOLD 94 Barcelona - FWD SOLD 92 Ebony - 3.90 SOLD 94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims |
