My shaft has stiff joints.
The propeller shaft, drive shaft, has stiff U-joints, that is.
![]() Any idea how long they will last?
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
Re: My shaft has stiff joints.
I have a propeller shaft with good u joints, but a torn center CV boot. Wanna trade? Doug
>>QUICKLY GRABBING DUCT TAPE. TAPING HANDS TO CHAIR ARMS TO AVOID TYPING <<
Okay Doug not long. The shaft is still free to move in and out. It's just that when I hold in the hand and and try some gyrations that it feels notchey at the joints. So you think the lubricant is all dried up inside? I guess after all that action in the past 180k miles it's pretty hard, the grease that is.
![]() So. Ah. Yes. I would like to trade. Please send me your drive shaft and I'll use it for the next 10 years and then I'll send it back to you with mine. ![]() So how much for a new drive shaft assembly? I may be looking at new front exhaust pipes and what the heck since the rack is original I might as well do that while I got everything apart and up on JACK STANDS.
MUST NOT BREAK DUCT TAPE, MUST NOT BREAK DUCT TAPE, MUST NOT BREAK DUCT TAPE . . . . .
Im right there with you Randy... LOL
Doesnt this belong in the "Not Exactly SVX" Forums? And thats awful personal stuff to talk about on this forum... ![]() ![]()
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse ![]() -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ![]() -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ![]() SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
The replacement driveshaft from Subaru is about $450 Doug
one word
WOW
So men the message here is this
don't get old. Your shaft and joints get stiff and are expensive to replace, welding only cures part of the problem and it requires the ends to be cut off
![]() Todd
Down to none ![]() |
>>BLOOD RUNNING DOWN CHAIR ARMS FROM CUTS CAUSED BY STRUGGLING AGAINST DAUNTLESS DUCT TAPE<<
Doug, I am thinking about injecting some grease or oil or something into the rubber seal on the u-joints with a needle. That's a lot of money for the drive shaft. But then again it last a long time ~ 10 years 200k miles. The exhaust has also lasted a long time. Maybe the replacement exhaust is worth the money too. How about the rear diff? Most likely needs a rebuild to reduce backlash. I changed the fluid in mine recently. It was changed about 100k ago and I was surprised that it was sort of gray looking. I'll have to change it more often.
So at about 200k replace the exhaust, propeller shaft, rack and and and and what else?
Re the suggestion of injecting grease/oil.
I have had good results and saved money and effort through greasing CV joinjts said to be US. Can you get grease in under the edge off the boot, after removing any attaching clip, using a gun or syringe ? Well worth a try. Randy, I trust you have a tool in hand to remove your restraints. Meantime enjoy ! ![]() ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Ya what he said. The joints are ussually stiff if you try to move them around alot, but if you think about it our shafts don't move around alot like in a strait axle car. The joints should work fine for a long time still, they don't really have to move that much anyway.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
The joints should work fine for a long time still, they don't really have to move that much anyway. [/B][/QUOTE]
Yup...marriage'll do that to 'ya. Ron (Duct tape be damned)!
Good s**t happened. ![]() '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
