I need to pull a wire from the engine compartment into the interior. Anyone know of a handy place or way to pull a wire into the cockpit, without having to drill a hole in the firewall? I spent a little time tonight looking, but didn't see anything obvious. Suggestions?
bill Green 95 SVX - Cleo Green 97 Outback - Maxine Red F-150 Extended Cab Long Bed - Big Boy Even the best monkey sometimes drops his banana. |
DUH! Pull it through the window.
Bzzzzzzzzt! Next ?
The only place I could find that was easy was on the passenger side where the drain tube for the A/C evaporator is. It was pretty easy. When and if you do it pull 2 of them through for future use if needed.
Mike 92 LSL Teal 103k 00 RS 2.5 Silverthorn Metallic 36k 68 Chevy Camaro 07 Forester XT Sport |
I'll check it out...
and let you know how it goes. Thanks.
speaking of the a/c drainage tube
when i first got my car, it was leaking on the passenger side making the floor mat wet and causing condensation. i had figured it was because of the rain,,,it wasn't. it turns out that my drainage tube had come off it's nossle. so, when i was defogging the windows (a/c kicks in to supplement), it was draining onto my floor instead of into the engine compartment.
toby [that's my quick tip for the day for those of you with wet passenger side floor mats.] |
Thanks, nubsjr
The drain hose route worked like a charm. I now have a functioning tranny temperature gauge. Thanks for the tip.
It just brings joy to my heart to know that a goups co-operation can help others. Oh wait.. Thats why I started this dern thing anyways. Good to see the concept works!
![]() Chris |
