View Poll Results: What clutch are you using? | |||
Stock cable operated | 0 | 0% | |
Aftermarket cable operated | 1 | 20.00% | |
Stock hydrolic operated | 1 | 20.00% | |
Aftermarket hydrolic operated | 3 | 60.00% | |
Voters: 5. You may not vote on this poll |
Thread Tools | Display Modes |
Clutch Curiosity
Just want to know what all the 5 speeders are using for a clutch.
I got an ATC that seams to handel drag launches well. (better than the tranny)
Not sure what I'm gonna run with the six speed yet
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
Exedy 13.5 lb flywheel, Exedy Sport clutch disk (organic) and pressure plate. Worked well until I smoked it once in a drag launch. Now it shudders badly in the morning. Going to try an ACT flywheel and clutch next time.
Mine used to shudder every once in a while (in the morning as well).
Mine slipped once during an autox (Sept 18/19) and hasn't shuddered since
