Yellowish headlights
guys, my headlights are getting yellowish every day. I made like 1000 times polish, it works at first, but by short time they return to yellow. can anyone think of a reason ??? and do the clear headlights conversion by smallcar really work (they do not become yellow) ?
Hi Spear, check out the how to folder for headlight cleaning. I use 1200 grit sandpaper followed by compound polish followed by wax. That seems to do the trick, if you feel adventureous you can bake the lights in an oven "make sure you read the how to on this one" open them up and clean the insides as well as the out. The clear headlights are nice but they are just that, there is no fluting like on the stock lenses. They would however look good for your application since you're shooting for a more modern look. If you can't find the cleaning in the how to try a search. Good luck!
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Get some medium cut rubbing compound. Rub it into the outside of the headlights and just rub em clear. Works wonders. And is much easier than having to open the headlights and clean the inside. You may have to do this once a week but it only takes 5 mins or your time. Quick and easy and works well.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
He said he's tired of doing that.
Danny, go grab some wet/dry sandpaper and go to town. I'd start at 220 or so, and wet sand up in incriments to about 1000. Clean it with rubbing alcohal, and apply a couple coats of clearcoat. Now your lights will be almost as clear as glass and it will last a long time. I did mine over a year ago and there is still no signs of yellowing. |
220 would probably be too agressive and you might not be able to the scratches out first, 1000-1200 sounded good. When I color sanded paint anything coarser than 600 was almost impossible to pollish out and plastic is much softer.
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere I decided to quit drinking, but I didn't like it so I quit not drinking. |
psst... don't use 240 grit valve lapping compound.
Patrick 1995 Ebony Pearl. S.N. 0001 "Araby" JDM Power Mode Switch, Integrated GPS/Video Player 6Xk Miles. 1992 Teal - Sold to Mysvxrocks [SIGPIC][/SIGPIC] |
Does this come from experence Mr. 7?
1000 is to light to start with. You have to get rid of the oxidation, and a lil bit more than that to really make sure it wont come back.
thank you all guys, you were most helpful
Start with 400, then 600, then 1000, then 1500, then 2000.
Alternate strokes with each grit. For example, run the 400 left and right, then the 600 up and down. That way you can tell when you are finished with each grit. If you see strokes from the previous grit, you have more sanding to do. using this method, when you get to the 2000, the lenses will be almost crystal clear and the polish will finish them up to be clearer than new. The secret to a great finish is alternating strokes. Doug
Wash with rubbing alcohol, then clear coat for several years of use. Doug
The inside doesn't yellow, it just gets an oily haze which gives it a yellowish hue. Doug
