Old 03-11-2005, 04:20 PM
FlagstaffSVX's Avatar
FlagstaffSVX FlagstaffSVX is offline
Jedi Member
Where else can coolant leak from?
I've replaced my cracked radiator and my thermostat. None of the hoses are cracked or leaking and yet, about halfway back, dripping from near my oil pan, I've got coolant coming out. The leak started small and now it's so bad I'm putting in a quart a day.
Pretty sure it's not the main seal, it's pure green that's coming out... What else is there that can leak?
-Craig Lowthorp, Flagstaff AZ
'92 LS-L, Black on White, 136k SOLD
'92 LS-L, Black on Silver, 120k SOLD
'01 Legacy Outback, White,
Old 03-11-2005, 05:28 PM
immortal_suby's Avatar
Thread Killah
On top of the engine underneath the intake on the driver side there are coolant hoses that connect to metal coolant lines. I had one spring a leak there at the connection and it dripped down as you mentioned. There is also coolant running through the throttle body. There are also coolant hoses going into the firewall that feed the heater core. Actually there are quite a few coolant hoses all over the place.
Locker Link
2015 BRZ Limited 6MT
Old 03-11-2005, 05:52 PM
kuoh kuoh is offline
A spot on my water pump rusted through and I had a leak similar to what you described.
KuoH
Old 03-12-2005, 07:54 AM
red95svx
Could be leaking right from the cylinder heads....
Old 03-12-2005, 11:13 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
I am inclined to agree with immortal_suby. I would check all the coolant lines. The throttle body is a good place to start. Let the car warm up and just follow the lines. you should find it.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
