Installing FWD 5-speed in AWD SVX
Quick question for those of you who are "in-the-know." I'm installing a FWD manual transmission in my 92 AWD SVX. What is done in the back to keep the back sides of the hub from being open (where the splined end of the axle shaft inserts)? Is there some sort of plug that goes there on the FWD models or something? Please advise.
Mike (Looking forward to roasting 225's) |
Some people have waaaay to much time on their hands
-Bill p.s. think duct tape
On another note, I have looked at the subaruparts.com diagrams, and compared there as well. I did not see any difference in the hubs/brake assembly from my 94 FWD to the 94 AWD (aside from the lack of ABS). BTW - Mike, what are you going to do with the spare rear-end parts? I am very much considering converting my FWD 4EAT to a AWD 5MT this summer. Let me know, I might take those parts off of your hands. |
I would just take the axle apart and leave the housing for the CV Joint there. In essence you could leave the whole dif on unless you're wanting to sell it.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
I also vote for grabbing a couple halfshafts and getting friendly with a hacksaw. I don't think balancing will be a huge issue since the radius from the center to the outside of the halfshaft is very small.
IggDawg is cool -IggDawg 1992 Teal SVX LS-L 160k miles 4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE 1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k |
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
That's only because they put the weights so far out on the wheel. the very inside of the wheel rotates at a much lower speed than the outside because the circumfrence is smaller. that's why you can put a castilated nut with a cotter pin through it on the axle without worrying about causing vibration (since the nut/cotter pin combo is far from symmetrical)
Stubs
Leave the wheels as they are and get two stub axle shafts from a wrecked FWD vehicle(they are only about 7-8 inches long). They will just bolt in the wheel with the axle nut the same as the axleshafts. Even if you have to order them from Subaru, they should not be tremendously expensive. If you want to save weight you not only remove the rear drive shaft, but also the rear differential AND the mounting frame for the rear differential. There should be a significant weight savings.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE Last edited by lhopp77; 04-02-2005 at 05:08 PM. |
Sorry Mike, I just offered my stubbs to Ben for his Auto-Xer.
altho just about any rear half shaft could be cut ang gutted to work.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
they are not just stube, the are basically the outer partys of the half-shafts. there needs to be something holding the wheels on.
Tom |
