Brake light blues
The (B) light has just appeared when I turn on the ignition and stays on all the time. I checked the fluid level it is good. What else causes this light to come on? What other checks can I make before entering the relm of $100.00/hour labor rates at the dealer? 92 SVZ still running strong at 85,000 miles- original transmission.
RobertB |
Setting your parking brake also turns this light on, doesn't it? Maybe your parking brake switch is faulty.
Dave |
I have never seen an "SVZ".......
with abs systems if this is the case alot of lights are set from frail wires. wires that brake from the wheels turning and hitting bumps. if not the parking brake inspect wires around calipers for cuts or brakes. if a broken wire soder and dont twist and tape.
If it was the ABS system, the ABS light would be on. Dave |
that is what i thought i couldnt remember if there was a abs light so his problem is the parking brake.
If the rubber gasket on the brake fluid cap is extended out, it could be pushing the float down. This would give a false warning light.
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
