Old 11-14-2005, 05:29 PM
davew833 davew833 is offline
Valve job value??
So I've got the heads off my '92 Pearl to replace the head gaskets. The local dealer talks me into buying the whole engine gasket kit, since it's got all the necessary seals at about the same price as just the head gaskets, valve cover gaskets, and cam seals. (BTW: Dealer was willing to beat Subaruparts.com's price with shipping.) Now since the car wasn't using any oil, I was just going to surface the heads, replace the gaskets, and call it good, but I've got all of these valve stem seals and things and I was wondering if it might be a good idea to get a valve job anyway since the heads are off. The cost of the machine work/seal installation is about $300 extra. My concern is that if do a valve job, my piston rings or bottom end will go out soon after. The engine has 160k miles. Any suggestions?
Old 11-14-2005, 06:46 PM
If you can afford/justify it then do it. Do you have any reason to believe the valve seals need to be replaced?
How confident are you of the person that would be doing the work for you?
Old 11-14-2005, 06:55 PM
No, I have no reason to believe the valve stem seals need to be replaced. The machine shop I would use was recommended by a family friend who owns a Honda/Acura repair shop.
Old 11-15-2005, 01:56 AM
if you are gonna do the heads, do also the bottom (rings...) it never works out for the engine if you do heads alone. in two weeks, you will need to overhaul the bottom again. The other way around only holds true, but you have to replace cam seals in the head only.
Old 11-15-2005, 04:04 PM
As you are going to surface the heads.
You will have to pull them down, so I would rebuild them with new springs and seals. Won't affect the rest of the engine.
Old 11-15-2005, 05:07 PM
Harvey I really respect you as an excellent member of this forum and THE MOST technically and mechanically informed but... on how much you wanna bet that if he does the heads alone, the engine bottom will get F***d up?
Come on he has a high mileage engine!!
Old 11-15-2005, 05:30 PM
Your a nice bloke too Danny , but 50 years experience and $100 says it won't happen.
Old 11-16-2005, 01:15 AM
Is that $100 Australian, Canadian or US ??
Old 11-16-2005, 03:57 PM
Genuine Ozzie, Micky Mouse Dollars. Worth $72 US, but worth a lot more now, that we qualified for the World Cup, last night
Harvey
Old 11-16-2005, 04:36 PM
Does this mean I have to have the valve job done so you guys can settle your bet? Who's going to chip in for financing that?
Old 11-16-2005, 05:25 PM
I keep my word of honor, that's from my part. Good luck Dave with the Heads alone..
Old 11-16-2005, 06:07 PM
Well Dave you, of course If you are going to get the heads faced, you will have to remove the cams and valves first. I dont think the valves or seats will need facing, as they are very durable, just a clean up. When you rebuild them, give the lifters a wash out, fit the new seals, and new springs, as they do loose tension over time, and its easier to do it then.
