Old 12-17-2005, 04:19 PM
mafuk
Question Svx alternator part number misunderstanding
Hello,
I have bad alternator, found new on ebay, but the part number differs, Mine is #23700AA190, sellers #23700AA190R1. Could it be the same?
Seller told that he took off the alternator from 1992 svx.
Mine svx is 1992, 3,3l, 4wd
Thanks in advance
Old 12-17-2005, 04:42 PM
intelisevil's Avatar
<<<Alcyone
Your part number 23700AA190 is an original factory part. 23700AA190R1 is a factory remanufactured part. This information is from www.subaruparts.com
Both are the correct part for our SVXi.
Good Luck,
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-17-2005, 05:16 PM
Green1995SVX
R1 always indicates a remanufactured part. In many cases, the Remanufactured part takes the place of the new part, and the new part is no longer available. I'm not sure if that's the case with this part though.
mike
Old 12-17-2005, 06:19 PM
Mafuk - welcome to the site. I hope you get the SVX fixed.
Old 12-17-2005, 08:13 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Personally I wouldn't buy a rebuilt one but would rather take mine to a local starter/alternator shop. They can and will rebuild it just as good if not better than any other rebuilder for 1/2 the price.
Old 12-18-2005, 04:11 AM
mafuk
Thank you,
I think I will buy the alternator. Mine alternator cant be repaired, because its body is damaged.
