Front wheel bearings?
I've got a hard-to-describe noise coming from the front left primarily during left turns, especially if they are starp, going up hill, and from a slower speed. As time has gone on, the "especiallies" aren't as applicable, and I can get it during right-hand turns or sometimes even when not turning. It's not a clicking sound, but maybe "scrunching" would describe it. It really sound bad A mechanic took a look when I had it in for a more urgent repair, and he said it's a combination of a bad half-shaft (which was my first guess) and a bad bearing.
I've heard a lot about rear wheel bearings going bad, but not much about front bearings. Does all the stuff about the rear bearings apply to the front ones too...the tendency for failure, the shipping/packing grease issue, the need for a press or hub tamer, the wrong gaskets listed, the same torques, etc.? Or are the fronts an easier and cheaper repair? |
I wouldn't say the tendency for failure for the rear is common at all for the fronts. The rears fail by far a million times more than the front. I think i've only read one other thread with someone saying there front bearings are bad in the two years ive been around here. Good luck in finding whats wrong.
- n00b
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
The front bearings are going bad on my 92 with over 222,000 miles. I replaced one already that was so bad you could move the tire a few mm top to bottom. The other side is only making the low howling noise at this point but needs to be replaced pretty soon also.
It is less common for the fronts to go at low mileage. I expect we will probbaly see some more failing as the miles rack up on more of the 92's and 93's. the symptoms on mine are as you described - started out only in some turns but got progressively worse and eventually made noise even in in a straight line.
i had to replace a front bearing not too shortly after i got my car on the road.
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
can someone try and describe the howling sound to me?
ive been reading all about this bearing business for a while now, and im wondering if my bearings are going bad, or if im just hearing normal tire-to-road noise... is there any perforamnce issues? |
i'm not too sure about the sound.
but i would imagine in the front more that your car would kind of wander around the road a little...bumpy ride ( i think).... sorry dont have my text book with me at work. i'll post up what i have in my text book in the later afternoon or evening. unless some one else has given out the answers to the questions.
wheel bearing diagnosis
symptoms of defective wheel bearing includes:
1. a hum, rumbling noise or growling noise that increases with vehicle speed. 2. roughness felt in the steering wheel that changes with the vehicle speed or conering. 3. looseness or excessive play in the steering wheel especially while driving over rough road surfaces 4. in severe cases, a loud grinding noise, indicating a defective front wheel bearing 5. pulling during braking 6. bearing roughness, heard and felt when, with the vehicle off the ground, rotating the wheel by hand. 7. bearing looseness felt when grasping the wheel at the top and bottom and wiggling it back and forth.
I would think it is the half shaft, and not a bearing, but I can't hear it.
I have a movie of a bad rear wheel bearing. Maybe your car sounds like this?
http://media.putfile.com/Really-a-bearing Also, I noticed that the wheel itself, when bolted on, has a good bit of play compared to other wheels. If you try to shake your wheels laterally (side to side) they shouldn't move at all. Bad bearings let the wheel move laterally. Also, it can be noticed if you take off the wheel and try to shake the hub...that'll shake also if the bearing is bad. When you do replace the bearing, replace all the seals and fill it with grease.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
