Part Out: Red '94 FWD
THIS PART OUT IS FINISHED. IF YOU PM'D ABOUT SUSPENSION PARTS, THEY MAY STILL BE AVAILABLE AT A LATER TIME. I STILL HAVE THE CAR, IT'S JUST TOO MUCH OF A HASSLE TO SHIP PARTS BECAUSE OF MY WORK SCHEDULE. ONCE I HAVE PULLED ALL THAT I INTEND TO KEEP, I WILL STRIP A FEW OTHER PARTS AND PUT THEM UP FOR SALE (INCLUDING SUSPENSION)
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me Last edited by SVX10; 07-26-2006 at 04:30 PM. |
Do you have a good front diff?
Yes, the front diff in the FWD transmission is fine. However, I'm not planning to disassemble the trans. It will go as a unit.
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
HENRY 92 SVX Claret(No More) 12 Camaro ZL1 89 Yamaha FJ1200 07 Yamaha FJR1300 "GO RAVENS" |
How much for a driverside doorsill strip. (the plastic trim piece that covers the edge of the carpet under the door.) With the white clips?
Mat,
How much for all the juicy lil' woodgrain-like interior pieces? Local of course... -Daniel
Insert Witty Quip Here... No more subie Current Cars: 96 Chevy Caprice Impala SS clone 93 Chevy Full-size blazer Soon: 2002 Honda CBR 954RR |
Actually, this has the gray dash bits. It's pretty good looking in my opinion if you want to come check it out.
Okay...here are the parts I'm thinking of taking off the car before sending it to a junk yard. Let me know if you want any of these, or if there is something else you want.
Available now: Struts Springs Wheels (no wheel caps) knuckles Window regulators Moving window glass Door seals (door side) Seats Gauge cluster Shift selector FWD transmission Starter Carpet Rear seat belts Front seat belts (automatic type) Gray pillar trim pieces Trunk carpet ECU FWD TCU Slash guards (including the one under the engine) RR Bumper Steering rack Tie Rod Ends This is about all I plan to pull before junking it. Let me know what you want Mat
radio cage with door?
sunvisors if they don't droop? |
Sorry...radio cage is gone. This is a strange part out car because half of the good stuff is already missing. Sorry
front passenger fender to 10514
http://www.subaru-svx.net/photos/fil...klix/36679.JPG
How much to 01938 please? if you think you can cut it out that section. Thanks alot.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
Jvan,
I'll send you a pic of the fender to make sure it's in good enough condition for you. There is a small dent right where the fender meets the plastic side skirt at the bottom. Speedklix, Not sure about cutting out that section. I have the tools to do it, but how much of it do you need?
