Its Alive!
Well after years of the car sitting. I finally tried starting it this morning. Started right up with the Electromotive ECU, as if it had never been shut down at all. I'm working through a few minor issues such as a frozen tensioner pully. Hope to be tuning this weekend.
Later Chuck
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
GREAT!
![]() Good luck with the tuning! ![]()
Chuck,
Great news! Keep us informed as to how the tuning goes! I'm very interested in what you see regarding AFR vs HP. -Bill
Update
I have still been trying to work out a few things with the car. My oxygen sensors seem to be all messed up. I was sensing a lean condition. Had the standard white smoke comming out. Then when I made fuel adjustments, I started getting black smoke (rich) and a strong fuel smell. My sensors were still reading lean. Both the wide band and the narrow band. I'm also having periodic communication errors with the ECU. I'm not sure why that is. I also have a small fuel leak, even after having the rails rewelded, so I need to pull that tonight and take it back to the shop where it was done. If I can get everything fixed this week, I'm going to try tuning again Sunday. I'm still amazed that the car is running as well as it is considering how long it has been out of commission and how poorly it is tuned right now.
i rode in that car today, a/c still works after sitting for 4 years!
92 LS-L been sitting for 6 years. 86 fiero gt, t-tops, 3800sc, headers, intercooler, p&p blower and lower intake, 3.0 pulley, 1.6RR's, double roller timing chain, xp cam, 130lb valve springs and hooisers :P 87 starion- currently rides on jackstands. |
Did you take the O2 sensors out of the exhaust pipes and "let them breathe" so the could reset before you did the fuel adjustments? -Bill
Breathing
Today
I shot off another e-mail to innovative about their wideband. Hopefully they will provide me with a unit that works. I'm going to call electromotive about the narrow band. I have a feeling they sent me the wrong unit. Supposed to be a 4 wire. I also need to go through the wiring and see if there is some kind of switched power problem going to my tec causing the communication failures. Boy that was frustrating. Not too thrilled with the engine mangement software. difficult to deal with. At least we didn't blow up the car. Stop by tomorrow if you want. We can catch the soccer game and at least feed you this time.
i would, but i'm afraid i have to leave for work in a few hours. when will i ever get to sleep
![]() btw this svx has one of the nicest interiors i've seen in a 14 yr old car. it's flawless from what i saw today. well except the pools of sweat from me. sorry about that.
SWEET!!!! looking forward to great results
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Take Care Chuck
Your Intercooler/Turbo Setup
Got some good info today
I called the Tec II rep from Extreme Turbo in Lakeland. Basically he told me that the sensors are fouled and need to be cleaned. This is done by using a blow torch to heat them until they are red hot. This can be done on the narrow band as well as the wide band. We should probably do it on your broad band too after blackening it up this weekend.
After analyzing the data and thinking a bit about what was going on. I think that the problem is that the high impedance injectors cannot be turned down enough to shoot the small amount of fuel necessary at idle. That is probably going to be my next hurdle, to set the minimum injector on time to its minimum, without shutting them down. I'm also going to turn down the fuel pressure regulator. Maybe that will help. So I should be ready to tune again this weekend. He also said that my laptop may need to be more dedicated to the purpose of loging data and dealing with this software, and that I should make sure all the extra programs are shut down when tuning and monitoring. That may help with the communication errors we were having.
your piping
my company wants me to work saturday.
