Old 08-30-2006, 08:24 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
I'm Clicking...
Today we were doing a photo shoot and I relized I was clicking up front. Popped the hood and noticed the sound was coming from my crank pulley. I wasn't spinning true (Round). I'm going to replace it but is there anything else I should check before replacing it?
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 08-30-2006, 09:24 PM
SVXelerator SVXelerator is offline
Frequent User
no....they have a history of going bad with age...post a picture of it once you take it off....it's most likely cracked
Maximum acceleration, maximum lateral g-force...it can be done, it just takes time and $$$
Old 08-30-2006, 09:34 PM
loose crank bolt.
As it is clicking, the bolt may have been a bit loose, for a while. So check the keyway, and look at the keyway in the belt sprocket behind it, to see if it is loose also.
Old 08-30-2006, 11:18 PM
gest24's Avatar
#1 6MT In Cali
She's going into the "Down" status for the next couple days till I get the Perrin lightened crank pulley. I don't think the bolt was loose considering Tom and I took it off and put it back on with the impact wrench.
RIP
84 VW Scirocco
02 WRX
Old 08-31-2006, 12:42 PM
gest24's Avatar
#1 6MT In Cali
I jsut noticed the clicking yesterday and you can ask Tom how anal I am about my Pearl eps. when it comes to the engine.
But when I dug into it today I took the belts off and went to loosen the bolt and it was already loose. Pulled everything off and everything looked ok. I think I'm still going to go with a lightened crank pulley only because mine has 96K on it. Everything looked ok but I'll take pics for you guys to diagnose.
RIP
84 VW Scirocco
02 WRX
