Old 09-03-2006, 05:21 PM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Drilled Rotors or Stock Rotors?
Ive been planning on replacing my front rotors because im getting some vibration when i brake now, but I dont know if i should buy drilled/slotted rotors or just replace them with OEM. I understand that the stock ones heat up quickly due to the weight of the vehicle and also that there to thin, but wouldnt drilled or slotted rotors be even thinner or weaker? Any suggestions?
Old 09-03-2006, 05:27 PM
Most members get slotted or dimple drilled rotors or slotted and dimple drilled rotors. The dimple drilled are drilled 1/8 inch into the rotor like the slot is and the rotor is not as weak as the ones drilled all the way through the rotor. It is a preference with what you want. Some members claim that the slotted are the best way to go. I haven't seen any proof of which are the best, but I would stay away from the drilled ones. Good luck. Oh, and if you are going to do that, the next best thing you can do is go to the braided stainless steel brake lines. They make a big difference.
Old 09-03-2006, 05:32 PM
AK Rowdy
Okay. Sounds good, thanks for the quick response.
Old 09-03-2006, 05:35 PM
AK Rowdy
For the stainless steel brake lines....how does that help braking? Do they allow brake fluid to flow better? To be honest, i dont know much about cars so any information would be helpful.
Old 09-03-2006, 05:56 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Crysis,
The SS lines won't expand as much as the stock brake lines when you press on the brake pedal, thus putting more hydraulic pressure on the pads, which results in firmer braking. Make sure to do a thorough job bleeding all of the air out of the system after you install them!
Earl was dead on with his suggestion to go with slotted or dimple drilled & slotted rotors. Going to these rotors with SS lines should be the first thing any new SVX owner does with their car.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-03-2006, 06:09 PM
I have been using slot and drilled rotors on my 92 LS-L for a year now with no problems so far and a lot better braking. I bought mine from NAPA with a lifetime warrenty the part numbers are PR86350L and PR86350R. They were a little spendy though. As far as the braided stainless steel brake lines go they are suppose to have less expansion and no blockage in the lines which equals quicker brake response. You can buy them off www.motorsportwarehouse.com. I installed a set on my car and I noticed a difference. I don't know what brake pads you are planning on going with ,but I recommend Akebono Pro-ACT ceramics they have a nice bite to them, last a long time(depending on how you drive I guess) and very low dusting. The part number for the front set is ACT333. I don't have part number for the rear set. Hope this helped some.
Old 09-03-2006, 07:04 PM
I have the RaceConcepts slotted/dimpled front and rear rotors, Goodridge stainless steel brake lines and the Akebono ProACT ceramic pads all around. They give me impressive braking performance under all conditions. They are quiet, do not squeal and produce no brake dust at all. In fact now my rear wheels now get dirty before my front ones do.
Until they warm up, their braking performance is equal to stock for the first stop or two. Once they do, the hotter they get, the better they perform. Highly recomended!
Old 09-04-2006, 09:13 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
Sometimes you get a vibration when you have to much PSi in the tires. I got my from RaceConcepts slotted and drilled with some pads to. in all it was about $510 with shipping. They will take about one week to get in
Old 09-04-2006, 10:49 AM
AK Rowdy
Thanks for all the help everyone. I'll be sure to take everything you guys said in consideration. How hard is it to replace a brake line? Is it under the How-To? Thanks again for all the help. I really appreciate it.
Aaron
Old 09-04-2006, 12:10 PM
I just looked and there is not a How-To on the brake lines. Sorry, that is one that we need to get in there with some pictures. I will work on that.
Old 09-04-2006, 01:04 PM
AK Rowdy
Alright, thank you
Old 09-04-2006, 03:40 PM
It is pretty straight forward in changing them. Just get all of the air out of the lines. It wouldn't hurt to flush the lines anyway. Good luck.
Old 09-04-2006, 07:02 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
A good set of undimpled or slotted rotors will stop a car faster than slotted/dimpled will 95% of the time. Mine lasted 140k on my SVX with no vibration whatsoever. Replaced because they were out of spec in size. You can get Chinese made rotors for about $40 a set fronts and $50 a set rears. Most are decent too, It is only when the rotors become insanely hot (which for normal spirited driving should never happen in reality). Changing fluid and bleeding the brakes does much more than anything I've ever noticed from ss lines. If you do decide to go with ss lines it isn't all that hard provided you know how to bleed brakes. I wouldn't waste my money buying them from a premade company as they tend to have plastic strut mount tabs (which will break from heat and then you just lost any advantage you might have gotten) besides, look in the phone book for a local hydrolic shop. Take you're old ones in and in a day you'll have industrial grade ss hoses for less than what you'd pay from an aftermarket supplier.
