Old 10-14-2006, 10:57 PM
kuroneko_sama's Avatar
kuroneko_sama kuroneko_sama is offline
aka sir_romeo
Send a message via MSN to kuroneko_sama Send a message via Yahoo to kuroneko_sama
i think i did something stupid.. mystery harnesses?
i have a 97 lsi
well i was in the fuse box (under the dash) and i noticed some harnesses that didnt connect to anything, i noticed two looked liked they belonged togehter so i plugged em together to see what would happen.. well when i started the car, my check engine light started BLINKING.... yes blinking... instead of jsut coming on for a few min and going off or something liek that it simply was blinking pretty rapidly and consistantly at regular intravals....
so i decided to unplug that harness ASAP... butthe light is still blinking.....
so i have now 3 questions
WTF are those harnesses for? and where do they lead? (the more specific the knowledge the more ill be able to sleep at night)
and what is now wrong with my car?
ill take a pic of the issue and circle the harness i connected
I Leave late and STILL manage to arrive early
Car #26..'97 SVX Silver (120k and climbing)
previous SVXi:
Car #24..'94 SVX Ebony 216k (sold)
car #18..'97 SVX LSI "Ebby" Pearl 175k (sold)
car #19..'97 SVX LSI Brilliant Red 103k (sold)
car #14..'92 SVX Claret LS-L Touring (sold)
car #13..'94 SVX Laguna Blue LS (sold)
Old 10-14-2006, 11:19 PM
aka sir_romeo
ok here is the culprit... any info?????
previous SVXi:
Old 10-15-2006, 12:18 PM
What code does it give?
Old 10-15-2006, 02:36 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
is sounds like you pluged in some older diainostic equipment... this 95 subaru i worked on had half the hook ups for the check engine light blink system one for the subaru slect monitor and one for obd II your prob. going to need to clear what ever code you triped in the OBD II system
- John
Old 10-15-2006, 03:28 PM
Archer999's Avatar
Archer999 Archer999 is offline
Arrow Blinking ligh
You may try and take off your ground on your battery, let it sit there for awhile and then hook it back up.
Allways looking for a cheap solution.
Old 10-18-2006, 10:12 PM
aka sir_romeo
well i unhooked the ground for a day... still blinking light... so i took the battery out of the car for another day.... when i put it back in...still blinking "check engine light" i had to use it to get to work... it drove fine, butthe blinking check ingine light is a concern.... anyone have any idea what those harnesses are???? anyone got like a book or something with schematics?
previous SVXi:
Old 10-19-2006, 08:36 AM
aka sir_romeo
well i had the codes read at my gf's dad's girage.. .and no codes were coming through.... apparently the code machine doesnt realise i have a check engine light blinking...... any thoughts when it was set to clear the codes it didnt change anything.....
so now to recap....
i have a blinking check engine light
the car is not giving off any codes
clearing the codes does not stop the blinking
disconnecting the battery does not stop the blinking
SOMEbody has had to have had this problem... i cant believe im the only one.
previous SVXi:
Old 10-19-2006, 08:55 AM
mikecg's Avatar
mikecg mikecg is offline
Well one thing to check is fuses. Hooking up things that arent supoose to be can blow fuses pretty quickly. You could have blow a fuse to something that isnt all that important or not regularly used. It's unlikely that something like that would be unnoticed but it is possible and doesnt take long to check and it's free.
Old 10-19-2006, 09:05 AM
Are you sure you unhooked the correct connectors?....
Old 10-19-2006, 10:10 AM
dcarrb dcarrb is offline
I don't know, man. You may be.
When I was little, being an inquisitive sort, I took a length of wire I'd found in my grandparents' barn and stuck it into a lamp socket.
Never did that again.
Sorry, kuroneko_sama, just messin' with you. Good luck sorting out the trouble.
dcb
Old 10-19-2006, 11:28 AM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
I connected the same 2 plugs together that you did and I didnt have any problems. :/
Old 10-19-2006, 12:06 PM
Does the car run?
Old 10-20-2006, 01:21 AM
aka sir_romeo
it runs fine as if there is nothing wrong
except the check engine light thingy....
what does that harness do if it worked fine on you
should it be plugged in???
im driving my van in the meantime not sure i should do too much till i at least know what happened...its hard to feel cool driving a minivan though
previous SVXi:
Old 10-20-2006, 01:31 AM
aka sir_romeo
there are only 2 that fit.... the other is the electric that do like the interior lights, power lock, and the key beepy thingy when you leave it in the ignition withthe door open....
the other was the ones i plugged in and got all blinky
so i unplugged it right away
if when he plugged them in and had no result.... should it be plugged in?? .. i only did it cause i thought maybe it became unplugged sometime and shoulda been in in the first place... stupid subaru...why have harnesses to nowhere, its liek a non working browning knob on a toaster
previous SVXi:
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
that sounds like my Check Engine Light. it tunrns on and off about every other day. but this is unrelated and i need to replace my O2 sensors sometime soon but it isn't dead yet because my gas mileage is as good as ever still
Anyway, hope you figure this out
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
