Old 11-07-2006, 12:48 PM
Shadow_Myst Shadow_Myst is offline
Trying to find fuel filter
Hi, I was wondering if someone could point me in the direction of the fuel filter? Is it in the gas tank or somewhere stupid like that, or is it fairly easy to get to?
thanks for the help
-=SM
Old 11-07-2006, 01:06 PM
Easy one. Under the hood by the fuse box & radiator overflow tank.
Old 11-07-2006, 01:08 PM
The fuel filter is the bright aluminum canister located at the rear of the engine compartment on the
driver's side, with the rubber houses going to the engine. Right behind the coolant reservoir
Old 11-07-2006, 01:32 PM
You just LOVE to show off your engine bay
Old 11-07-2006, 01:42 PM
Manarius's Avatar
Manarius Manarius is offline
Hah, that's exactly where it is on my car as well.
-Jason
-Obi Wan Kenobi
Old 11-07-2006, 01:52 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
dang I'm jealous....mine's more dirtier
1995 Subaru Svx L / AWD
Old 11-07-2006, 01:55 PM
But if you want to see REALLY clean, Harry Newman (newsvx) is the one to beat! No matter how deep into the
engine compartment you look, its just perfect. Even a remote controlled Dremel couldn't get to some of the nooks
and crannies that are just naturally pristine as in Harry's.
Old 11-07-2006, 07:39 PM
Thanks
Thanks a lot guys.. I may replace it tomorrow.. and suggestions on what tolls I might not think of and will need?
Thx
-=SM
Old 11-07-2006, 08:33 PM
You should be able to do it with just a phillips screwdriver. Those hoses get stubborn at times though so be careful not to tear them. FI hose is expensive compared to regular fuel line.
Old 11-07-2006, 08:47 PM
Speedklix's Avatar
Locker Link Solution
Its also the same filter
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-08-2006, 07:19 PM
Damn hoses
hey everyone, are there any tricks for getting the hoses off?? I was not able to get them to seperate. Is there vacume pressure or anything that could be released? Thanks a lot.
-=SM
Old 11-08-2006, 07:56 PM
No tricks, its just that the hose has bonded itself to the fitting. If you take pliers and twist the hose it will sometimes help break the bond. Or use a screwdriver to gently push the hose off.
If all else fails, cut and replace. Just take the old hoses to any auto parts store and they should be able to hook you up with the proper size of tubing. But the other end of the feed line is a pain to get to where it meets the firewall
Old 11-08-2006, 09:15 PM
poweredx2 poweredx2 is offline
I have never seen a car that clean,trust me he drives that svx around inside the house,great job.
Old 11-08-2006, 09:38 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You can relieve the fuel pressure somewhere behind the passenger seat (check your manual) but it's not necessary. Just try to pry the hose open enough to spray liquid wrench or similar into it. Then pull and rotate slowly by hand. If you use a pliers, place a cloth between the pliers teeth and hose, this will prevent damage to the hose.
